Up to 20% off select tools
Aranet 4 Display Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
107
All Time:
1,175
Comments: 8
8 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the display on the Aranet 4 Home
The aranet 4 uses a 1.54 inch (3.9 centimeters) E-ink display, when dropped the glass on the back of the screen can break causing the display to be stuck on whatever was last shown.
    1. Aranet 4 Display Replacement, Disassembly: step 1, image 1 of 2 Aranet 4 Display Replacement, Disassembly: step 1, image 2 of 2
      • Remove the battery door and the batteries.
      • Unscrew the two T6 screws.
      • Turn your device over so that the screen faces you and remove the cover.
      Ask FixBot
    2. Aranet 4 Display Replacement, Removing the old screen: step 2, image 1 of 3 Aranet 4 Display Replacement, Removing the old screen: step 2, image 2 of 3 Aranet 4 Display Replacement, Removing the old screen: step 2, image 3 of 3
      • Pull back the screen.
      • Carefully release the display ribbon cable by, depending on your board revision either lifting the brown cover on the flip-up connector or sliding out the stuffer actuator connector. (Refer to the images for clarification.)
      • Remove the old screen.
      Ask FixBot
    3. Aranet 4 Display Replacement, Placing new screen: step 3, image 1 of 1
      • Insert the new screen's cable into the connector (black side up).
      • Carefully place the front cover back and reassemble the device.
      Ask FixBot
It is not necessary to remove the the board from the bottom-case, if you do wish to do this be carefull not to break the battery terminals!
3 other people completed this guide.
Author
with
spoofer
167 Reputation
1 Guide authored
8 Guide Comments
Great info and instruction. But….. amazone does not ship to The Netherlands.
Cees Doets - Reply Share
Hi Cees,
You can look for products sold on amazon in different countries using the ASIN number.
Here's a link for the Netherlands: https://www.amazon.nl/dp/B071HW4Z6N
Good luck with your repair!
spoofer - Reply Share
Thanks a lot! Great info.
Yes yes yes. Both my Aranet’s work again.
Thanks for the guide! I successfully repaired my Aranet4 by following it. A couple of notes:
- I was able to get a better price than Amazon for the replacement display at https://www.waveshare.com/product/displa....
- The connector for the flexible printed circuit board on my model didn't flip up, but instead slides forward. I found documentation for the connector (or something very very similar to it) here: https://www.te.com/content/dam/te-com/do... (search for "Stuffer Actuator (Plunger Style)")
Jon Manning - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 107
All Time: 1,175
