Aquarium Top Filter Box Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
85
All Time:
1,562
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken filter box with a regular plastic box. This guide will provide you with the instructions and tools to repair your aquarium top filter. The added benefit you can achieve from this guide is that you can customize the filtration system best suited for your aquarium. The tools listed in this guide are easily accessible and can be found online or in any hardware store.
    1. Aquarium Top Filter Box Replacement, Aquarium Filter Box: step 1, image 1 of 2 Aquarium Top Filter Box Replacement, Aquarium Filter Box: step 1, image 2 of 2
      • Using a black sharpie marker, mark the box for accurate holes.
      • Make sure the hole is a little bit smaller than the soft PVC pipe.
      Ask FixBot
    2. Aquarium Top Filter Box Replacement: step 2, image 1 of 2 Aquarium Top Filter Box Replacement: step 2, image 2 of 2
      • Use the utility knife to cut a hole in the marked position to attach the pipe.
      • Be very careful as the box is difficult to cut.
      Ask FixBot
    3. Aquarium Top Filter Box Replacement: step 3, image 1 of 2 Aquarium Top Filter Box Replacement: step 3, image 2 of 2
      • Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
      Ask FixBot
    4. Aquarium Top Filter Box Replacement: step 4, image 1 of 1
      • Attach the soft PVC pipe with the aquarium powerhead.
      • Make sure it is properly connected.
      Ask FixBot
    5. Aquarium Top Filter Box Replacement: step 5, image 1 of 2 Aquarium Top Filter Box Replacement: step 5, image 2 of 2
      • Insert the soft PVC pipe in the plastic box.
      Ask FixBot
    6. Aquarium Top Filter Box Replacement: step 6, image 1 of 3 Aquarium Top Filter Box Replacement: step 6, image 2 of 3 Aquarium Top Filter Box Replacement: step 6, image 3 of 3
      • With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
      Ask FixBot
    7. Aquarium Top Filter Box Replacement: step 7, image 1 of 3 Aquarium Top Filter Box Replacement: step 7, image 2 of 3 Aquarium Top Filter Box Replacement: step 7, image 3 of 3
      • Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
      • Make sure to let the silicone glue dry for 30 minutes.
      Ask FixBot
    8. Aquarium Top Filter Box Replacement: step 8, image 1 of 3 Aquarium Top Filter Box Replacement: step 8, image 2 of 3 Aquarium Top Filter Box Replacement: step 8, image 3 of 3
      • Add your desired filter media best suited for your aquarium.
      • Finally, submerge the waterpump in water and adjust the waterflow.
      • Be careful were you place the inlet of the filter, so no organisms or substrate get sucked in and die inside or clog it. If needed you can put some filter floss or a sponge on the inlet to prevent the above.
      Ask FixBot
Seaaf
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 85
All Time: 1,562
