Aquaris M5 Mainboard Replacement
    1. Aquaris M5 Mainboard Replacement, Back Cover: step 1, image 1 of 2 Aquaris M5 Mainboard Replacement, Back Cover: step 1, image 2 of 2
      • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
      • Between the 2 SIM card slots is a good place to start.
      • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
      Ask FixBot
    2. Aquaris M5 Mainboard Replacement: step 2, image 1 of 2 Aquaris M5 Mainboard Replacement: step 2, image 2 of 2
      • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
      • Slide around the corner and along the top edge, to also disconnect these clips.
      Ask FixBot
    3. Aquaris M5 Mainboard Replacement: step 3, image 1 of 3 Aquaris M5 Mainboard Replacement: step 3, image 2 of 3 Aquaris M5 Mainboard Replacement: step 3, image 3 of 3
      • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
      • Grab the back cover by the loosened edge.
      • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
      • Take off the back cover.
      Ask FixBot
    1. Aquaris M5 Mainboard Replacement, Battery: step 4, image 1 of 1
      • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
      • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
      • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
      Ask FixBot
    2. Aquaris M5 Mainboard Replacement: step 5, image 1 of 3 Aquaris M5 Mainboard Replacement: step 5, image 2 of 3 Aquaris M5 Mainboard Replacement: step 5, image 3 of 3
      • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
      • Twist the spudger to lift up the mainboard shield.
      • Remove the mainboard shield from the phone.
      Ask FixBot
    3. Aquaris M5 Mainboard Replacement: step 6, image 1 of 2 Aquaris M5 Mainboard Replacement: step 6, image 2 of 2
      • Use a spudger to disconnect the battery's flex cable from the mainboard.
      • Pull of the sticker on the bottom side of the battery.
      • Grab the sticker and lift it up to take the battery out of the phone.
      Ask FixBot
    1. Aquaris M5 Mainboard Replacement, Front Camera: step 7, image 1 of 3 Aquaris M5 Mainboard Replacement, Front Camera: step 7, image 2 of 3 Aquaris M5 Mainboard Replacement, Front Camera: step 7, image 3 of 3
      • FPC Connectors can break easily, be very careful.
      • Use an opening tool or your finger nail to open the FPC connector.
      • Disconnect the FPC connector cable.
      • Use the tip of a spudger to leverage the camera out of its housing.
      • Remove the front camera.
      Ask FixBot
    1. Aquaris M5 Mainboard Replacement, Rear Camera: step 8, image 1 of 2 Aquaris M5 Mainboard Replacement, Rear Camera: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use the flat side of a spudger to disconnect the camera's flex cable.
      • Use Tweezers to grab the camera and lift it out of the phone.
      Ask FixBot
    1. Aquaris M5 Mainboard Replacement, Mainboard: step 9, image 1 of 3 Aquaris M5 Mainboard Replacement, Mainboard: step 9, image 2 of 3 Aquaris M5 Mainboard Replacement, Mainboard: step 9, image 3 of 3
      • Use a SIM card eject tool, to eject the two SIM card slots on one side.
      • Use a SIM card eject tool, to eject the micro SD card slot on the other side.
      Ask FixBot
    2. Aquaris M5 Mainboard Replacement: step 10, image 1 of 3 Aquaris M5 Mainboard Replacement: step 10, image 2 of 3 Aquaris M5 Mainboard Replacement: step 10, image 3 of 3
      Buy
      • Use tweezers to unplug the antenna cable in the bottom right of the mainboard.
      • Use a spudger to disconnect the two flex cables at the bottom of the mainboard.
      Ask FixBot
    3. Aquaris M5 Mainboard Replacement: step 11, image 1 of 2 Aquaris M5 Mainboard Replacement: step 11, image 2 of 2
      • Use the flat end of a spudger to disconnect the flex cable at the top of your the mainboard.
      • Bend the cable a bit over the edge, so it won't block the mainboard later, when you are taking it out.
      Ask FixBot
    4. Aquaris M5 Mainboard Replacement: step 12, image 1 of 1
      • Take out the 4mm Phillips #00 screw, holding the mainboard to the frame.
      Ask FixBot
    5. Aquaris M5 Mainboard Replacement: step 13, image 1 of 3 Aquaris M5 Mainboard Replacement: step 13, image 2 of 3 Aquaris M5 Mainboard Replacement: step 13, image 3 of 3
      • Insert the flat end of a spudger between the mainboard and the mid frame.
      • The best spot is on the right side next to the two SIM card slots.
      • Use the spudger to lever the mainboard.
      • Take the mainboard out of the phone.
      Ask FixBot
Theo Mat
13,019 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 109
All Time: 1,357
