Apple iPod Hi-Fi Grille Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
74
All Time:
2,441
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide details how to replace the front grille of the Apple iPod Hi-Fi speaker system.
Tools
    1. Apple iPod Hi-Fi Grille Replacement, Grille: step 1, image 1 of 1
      • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
      • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
      Ask FixBot
    2. Apple iPod Hi-Fi Grille Replacement: step 2, image 1 of 1
      • Take one spudger and fit it under the grille.
      • Use your first spudger to pry up and make room to insert a second one.
      • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
      • Use the other spudger to raise the grille, allowing you to see where you're working.
      • Since you're cutting the glue, the grille may not stick as well when reassembled.
      Ask FixBot
    3. Apple iPod Hi-Fi Grille Replacement: step 3, image 1 of 1
      • Pull the grille off the Apple iPod Hi-Fi with your hands.
      Ask FixBot
5 other people completed this guide.
Timothy Scheuermann
710 Reputation
3 Guides authored
Cal Poly, Team S16-G1, Livingston Spring 2018 Member of Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 74
All Time: 2,441
