Apple XServe Raid Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
81
All Time:
1,504
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your Xserve 2,1 is showing an error in Raid Utility about the backup battery, this guide will show you how to replace the raid battery in the system.
The raid battery serves as a way to write cached data to the system drives if there is a power failure. This ability is important in systems with raid, as it protects the user from data loss.
If the raid battery has recently been replaced, ensure that the system has been powered on for a minimum of 72 hours and battery conditioning has finished.
Before using this guide, ensure that you have a grounded working surface and anti-static wristband. Static electricity may cause damage to the internal components of the system.
Always dispose of the battery according to local laws and regulations, and if the battery has become swollen, make sure not to damage the enclosure.
Parts
Tools
    1. Apple XServe Raid Battery Replacement, Raid Battery: step 1, image 1 of 2 Apple XServe Raid Battery Replacement, Raid Battery: step 1, image 2 of 2
      • Remove the drive module(s) from the front of the Xserve.
      • Depending on configuration, there may be up to three modules.
      Ask FixBot
    2. Apple XServe Raid Battery Replacement: step 2, image 1 of 1
      • Remove the power supplies from the system by pulling on the built-in removal bar.
      • Depending on configuration, there may only be one power supply unit.
      Ask FixBot
    3. Apple XServe Raid Battery Replacement: step 3, image 1 of 1
      • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
      • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
      Ask FixBot
    4. Apple XServe Raid Battery Replacement: step 4, image 1 of 3 Apple XServe Raid Battery Replacement: step 4, image 2 of 3 Apple XServe Raid Battery Replacement: step 4, image 3 of 3
      • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
      Ask FixBot
    5. Apple XServe Raid Battery Replacement: step 5, image 1 of 1
      • Disconnect the raid battery connector using a plastic spudger.
      Ask FixBot
    6. Apple XServe Raid Battery Replacement: step 6, image 1 of 2 Apple XServe Raid Battery Replacement: step 6, image 2 of 2
      • Remove the SAS backplane power cable by pulling the cable out of the board.
      • Remove the data cable from the board using a spudger to lift the connector out of the socket.
      • Loosen the Phillips #0 screw holding the backplane in the system.
      • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
      Ask FixBot
    7. Apple XServe Raid Battery Replacement: step 7, image 1 of 1
      • Loosen the single Phillips #0 screw on the power backplane.
      • Slide the backplane out of the connector on the main board, and lift it straight out.
      Ask FixBot
    8. Apple XServe Raid Battery Replacement: step 8, image 1 of 1
      • Lift the raid card battery out of the chassis.
      Ask FixBot
2 other people completed this guide.
Cody West
243 Reputation
1 Guide authored
Texas Tech, Team S14-G2, Cowan Fall 2020 Member of Texas Tech, Team S14-G2, Cowan Fall 2020
TTU-COWAN-F20S14G2
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 81
All Time: 1,504
