Introduction
Go to step 1 ↓Follow this guide to replace a cracked or broken sensor assembly in your Apple Watch Ultra 2. The sensor assembly includes the skin-facing sensors along with the back panel that houses the sensors.
Since the sensor assembly uses screws to compress against the perimeter gasket, you can normally reuse the gasket during reassembly. However, you may still lose some water resistance once you open up the watch.
Tools
Spudger4.9
Use a P5 Pentalobe driver to remove the four 2.2 mm‑long screws securing the sensor assembly.
Heat an iOpener and apply it to the sensor assembly for at least two minutes to loosen the adhesive underneath.
Insert an iFlex in the seam between the watch frame and the top edge of the sensor assembly to create a gap.
Carefully twist the iFlex to widen the gap.
Insert an opening pick into the gap you created.
Remove the iFlex.
Slide the opening pick around the top right corner of the sensor assembly and along the right edge to slice its adhesive.
Carefully lift the top edge of the sensor assembly with your opening pick until you can get a good grip with your fingers.
Lift the sensor assembly and carefully pull it towards the bottom edge of the watch.
Swing the sensor assembly open to an upward position.
Use a spudger to pry and disconnect the sensor assembly cable from its socket.
