This teardown is not a repair guide. To repair your Apple Watch SE, use our service manual.
  1. Apple Watch SE Mother Board Removal, Removing the Taptic Engine: step 1, image 1 of 2 Apple Watch SE Mother Board Removal, Removing the Taptic Engine: step 1, image 2 of 2
    • Unscrew Tri-screw and remove small plate cover.
    • Then, remove these two Tri-screws.
    Ask FixBot
  2. Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: step 2, image 1 of 3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: step 2, image 2 of 3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: step 2, image 3 of 3
    • Undo both connectors highlighted.
    • Then the Taptic engine should be able to be lifted out.
    • The Taptic engine has some adhesive on the cable outlined in blue that sticks it to the speaker.
    Ask FixBot
  3. Apple Watch SE Mother Board Removal, Removing the Speaker: step 3, image 1 of 3 Apple Watch SE Mother Board Removal, Removing the Speaker: step 3, image 2 of 3 Apple Watch SE Mother Board Removal, Removing the Speaker: step 3, image 3 of 3
    • Disconnect this connector.
    • Then remove these 3 tri-screws.
    Ask FixBot
  4. Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: step 4, image 1 of 2 Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the speaker slowly.
    • Where my tweezers are located seems to be the best place to remove the speaker.
    Ask FixBot
  5. Apple Watch SE Mother Board Removal, Removing Brackets around the MB: step 5, image 1 of 3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: step 5, image 2 of 3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: step 5, image 3 of 3
    • 4 more Tri-screws are removed here.
    • Gently pulling back the screen flex cables reveals 2 more Tri-screws that should be removed.
    • Then the brackets can be removed with tweezers.
    Ask FixBot
  6. Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: step 6, image 1 of 2 Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: step 6, image 2 of 2
    • Remove these 2 Tri-screws.
    • After taking off the first bracket, take of the next Tri-screw and remove the second bracket.
    Ask FixBot
  7. Apple Watch SE Mother Board Removal, Disconnecting Power button: step 7, image 1 of 2 Apple Watch SE Mother Board Removal, Disconnecting Power button: step 7, image 2 of 2
    • Disconnect the Power button FPC.
    • The FPC here has 2 connections. DO NOT pry in the middle as it may bend.
    Ask FixBot
  8. Apple Watch SE Mother Board Removal, Removing the MB.: step 8, image 1 of 3 Apple Watch SE Mother Board Removal, Removing the MB.: step 8, image 2 of 3 Apple Watch SE Mother Board Removal, Removing the MB.: step 8, image 3 of 3
    • Starting in the bottom right corner as show here. Gently wedge in a spudger and pry up on the board.
    • Once you are able to get a good hold on the board move try pulling down and to the right in a clockwork motion.
    • Do this motion slowly as there is a final connector under the board.
    Ask FixBot
  9. Apple Watch SE Mother Board Removal, Completion: step 9, image 1 of 1
    • Once the board is lifted out, the final connector is highlighted.
    • Disconnect and you are all done!
    • Repeat steps backwards to put everything back together.
    Ask FixBot
jessepugsley
181 Reputation
1 Guide authored
1 Guide Comment
thank you so much
Wesleyfraga - Reply Share
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 140
All Time: 8,669
