Apple Watch - Series 10 (46mm) Battery Replacement
    1. Apple Watch - Series 10 (46mm) Battery Replacement, Prepare your watch for disassembly: step 1, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Prepare your watch for disassembly: step 1, image 2 of 2
      • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
      • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
      Ask FixBot
    2. Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: step 2, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: step 2, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: step 2, image 3 of 3
      • Throughout the rest of your repair:
      • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
      • To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
      • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
      Ask FixBot
    3. Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: step 3, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: step 3, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your watch. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    4. Apple Watch - Series 10 (46mm) Battery Replacement, Heat the screen: step 4, image 1 of 1
      • Strong adhesive secures the perimeter of the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
      • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the screen and/or battery.
      Ask FixBot
    5. Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: step 5, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: step 5, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: step 5, image 3 of 3
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
      • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
      Ask FixBot
    6. Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the screen: step 6, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the screen: step 6, image 2 of 2
      • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
      • With one hand, push down firmly on the watch's frame to secure it in place.
      • With your free hand, hold the iFlex and push the edges up to make it more rigid.
      • The iFlex should be slightly "U" shaped.
      • Pry up the screen enough for the iFlex to lay flat on its own.
      • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
      • Leave the iFlex inserted under the screen.
      Ask FixBot
    7. Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: step 7, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: step 7, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: step 7, image 3 of 3
      • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
      • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
      • Insert an opening pick between the screen and iFlex.
      • Remove the iFlex.
      Ask FixBot
    8. Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: step 8, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: step 8, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: step 8, image 3 of 3
      • Slide the opening pick around the bottom left corner and up the left edge.
      Ask FixBot
    9. Apple Watch - Series 10 (46mm) Battery Replacement: step 9, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement: step 9, image 2 of 2
      • Continue sliding your pick along the top edge and around the top right corner, stopping just after the digital crown.
      • Don't slide your pick past the digital crown—you risk damage to the screen cables.
      Ask FixBot
    10. Apple Watch - Series 10 (46mm) Battery Replacement, Separate the remaining adhesive: step 10, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the remaining adhesive: step 10, image 2 of 2
      • Insert the long edge of an opening pick between the left edge of the screen and frame.
      • Twist the pick to lift the screen and separate any remaining adhesive.
      Ask FixBot
    11. Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: step 11, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: step 11, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: step 11, image 3 of 3
      • Pull the right edge of the screen over the digital crown.
      • If the screen feels stuck, go back around it with an opening pick to separate any adhesive.
      • Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
      • During reassembly:
      • This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
      • Follow this guide to apply new screen adhesive and reseal your watch.
      Ask FixBot
    1. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery connector screw: step 12, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery connector screw: step 12, image 2 of 2
      • Use a tri‑point Y000 screwdriver to remove the 1.1 mm‑long screw securing the battery connector bracket.
      Ask FixBot
    2. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the bracket: step 13, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the bracket: step 13, image 2 of 2
      • Use tweezers to remove the battery connector bracket.
      • During reassembly, make sure the longer section of the bracket goes over the battery press connector.
      Ask FixBot
    3. Apple Watch - Series 10 (46mm) Battery Replacement, Disconnect the battery: step 14, image 1 of 2 Apple Watch - Series 10 (46mm) Battery Replacement, Disconnect the battery: step 14, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    4. Apple Watch - Series 10 (46mm) Battery Replacement, Heat the battery adhesive: step 15, image 1 of 1
      • Heating the battery will soften the strong adhesive securing it, making the battery easier to remove.
      • Heat an iOpener and lay it on the battery for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the battery.
      Ask FixBot
    5. Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: step 16, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: step 16, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: step 16, image 3 of 3
      • Be careful not to puncture or bend the battery—it can leak dangerous chemicals and catch fire.
      • Insert an opening pick between the bottom edge of the battery and frame.
      • Pry up the battery with the opening pick until it starts to separate from the frame.
      • This requires time and constant pressure. If you're having trouble, apply more heat and try again.
      • Slide the pick farther under the battery and lift until all the adhesive is separated.
      Ask FixBot
    6. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: step 17, image 1 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: step 17, image 2 of 3 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: step 17, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Remove the battery from the frame.
      • To install a new battery:
      • Use a spudger and tweezers to remove all the old adhesive from the battery recess.
      • If your replacement battery doesn't have adhesive pre-installed, put strips of thin, double-sided tape on the logic board (not directly on the battery) where the old adhesive was.
      • Reconnect the battery cable press connector to its socket on the motherboard.
      • Remove any liners from the battery adhesive or double-sided tape.
      • Firmly press the battery into place to secure it with the adhesive.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing your repair.
3 other people completed this guide.
Alex Diaz-Kokaisl
247,437 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,712 Guides authored
1 Guide Comment
This was a great walk-thru for a battery replacement, thanks for all you do!
Deeno - Reply Share
Past 24 Hours: 29
Past 7 Days: 171
Past 30 Days: 883
All Time: 10,710
