Apple Time Capsule Model A1254 Fan Replacement
    1. Apple Time Capsule Model A1254 Fan Replacement, Back Plate: step 1, image 1 of 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: step 1, image 2 of 3 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: step 1, image 3 of 3
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      Ask FixBot
    2. Apple Time Capsule Model A1254 Fan Replacement: step 2, image 1 of 2 Apple Time Capsule Model A1254 Fan Replacement: step 2, image 2 of 2
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      Ask FixBot
    3. Apple Time Capsule Model A1254 Fan Replacement: step 3, image 1 of 2 Apple Time Capsule Model A1254 Fan Replacement: step 3, image 2 of 2
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      Ask FixBot
    1. Apple Time Capsule Model A1254 Fan Replacement, Fan: step 4, image 1 of 2 Apple Time Capsule Model A1254 Fan Replacement, Fan: step 4, image 2 of 2
      • Orientate the back plate so that the fan is facing away from you.
      • Use the #0 Phillips Screw Drive to push the rubber shock mounts through the back plate.
      • Make sure that the head of the screw driver is centered on the head of the rubber shock mount so that it doesn't slip off causing possible injury.
      • When attaching the new fan, push the new rubber shock mounts through the back plate first. Attach the fan once all mounts are inserted.
      Ask FixBot
3 other people completed this guide.
JR Alfano
543 Reputation
1 Guide authored
Cal Poly, Team 4-2, Livingston Fall 2016 Member of Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Members
60 Guides authored
2 Guide Comments
Hi where can I find the new rubber shock mount replacement for A-1254 fan replacement? thx.
V Q - Reply Share
How do I get the rubber feet off the old fan and put them on the new fan?
Jim Matthews - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 56
All Time: 5,413
