Up to 20% off select tools
Apple Thunderbolt Display LCD Replacement
Views: 40K
View statistics:
Past 24 Hours:
9
Past 7 Days:
87
Past 30 Days:
365
All Time:
40,124
Comments: 48
35 comments on steps, 13 guide comments.
Go to guide comments
Completed: 30
30 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The LCD in the Apple Thunderbolt Display is the very first part that will have to be taken out no matter what piece inside this device has to be replaced. Because of this, it is essential to know how to carefully remove the LCD from the device. Something that should be noted is that even after screws are removed, don't hastily try pulling the LCD out of its casing because it is still connected to the power and logic board of the display! Once the new screen is in place, make sure that everything is connected like the original LCD was and your device should be as good as new!
Important – LCD Flex Cable Orientation and Connection
When removing or reinstalling the LCD panel, special attention must be paid to the LCD flex cable connecting the panel to the logic board. This cable carries not only the display data signals, but also the power supply lines (LCD_PWR) required for the panel and T-CON controller to operate.
If the flex cable is installed in the wrong orientation, partially inserted, or misaligned:
  • The display may show no image,
  • The backlight may fail to turn on,
  • In rare cases, protective components such as fuses or ferrite beads on the logic board may be damaged.
When reconnecting the flex cable:
  • Ensure the gold contact pads face the connector’s internal pins,
  • Make sure the cable is fully and evenly seated in the connector,
  • Verify that all locking tabs are properly secured.
⚠️ Always double-check all flex cable connections before reconnecting power.
    1. Apple Thunderbolt Display LCD Replacement, LCD: step 1, image 1 of 3 Apple Thunderbolt Display LCD Replacement, LCD: step 1, image 2 of 3 Apple Thunderbolt Display LCD Replacement, LCD: step 1, image 3 of 3
      • Lay down the display with screen side up.
      • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
      • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
      • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
      Ask FixBot
    2. Apple Thunderbolt Display LCD Replacement: step 2, image 1 of 2 Apple Thunderbolt Display LCD Replacement: step 2, image 2 of 2
      • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
      Ask FixBot
    3. Apple Thunderbolt Display LCD Replacement: step 3, image 1 of 2 Apple Thunderbolt Display LCD Replacement: step 3, image 2 of 2
      • Slowly lift the LCD out from its placement and tilt it upwards.
      • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
      • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
      Ask FixBot
    4. Apple Thunderbolt Display LCD Replacement: step 4, image 1 of 3 Apple Thunderbolt Display LCD Replacement: step 4, image 2 of 3 Apple Thunderbolt Display LCD Replacement: step 4, image 3 of 3
      • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
      Ask FixBot
    5. Apple Thunderbolt Display LCD Replacement: step 5, image 1 of 3 Apple Thunderbolt Display LCD Replacement: step 5, image 2 of 3 Apple Thunderbolt Display LCD Replacement: step 5, image 3 of 3
      • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
      • Flip the metal bar over using the tape as a handle.
      • Next, grab onto the connector and slowly pull it from the socket in the logic board.
      Ask FixBot
    6. Apple Thunderbolt Display LCD Replacement: step 6, image 1 of 3 Apple Thunderbolt Display LCD Replacement: step 6, image 2 of 3 Apple Thunderbolt Display LCD Replacement: step 6, image 3 of 3
      • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
      Ask FixBot
    7. Apple Thunderbolt Display LCD Replacement: step 7, image 1 of 1
      • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
      Ask FixBot
    8. Apple Thunderbolt Display LCD Replacement: step 8, image 1 of 2 Apple Thunderbolt Display LCD Replacement: step 8, image 2 of 2
      • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
      • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
      Ask FixBot
30 other people completed this guide.
Author
with
Calvin Laverty
2,310 Reputation
4 Guides authored
Cal Poly, Team 5-11, Maness Spring 2015 Member of Cal Poly, Team 5-11, Maness Spring 2015
CPSU-MANESS-S15S5G11
4 Members
60 Guides authored
13 Guide Comments
Now I just need to find the affordable replacement LCD Panel. Mine is not too bad - but it has recently developed a streak on one side that is very irksome.
gigabob - Reply Share
Love your site! Proved very helpful on multiple occasions and your products are fantastic!
Forgive my ignorance...
Is it possible to (1) Are any of the components of Thunderbolt Display upgrade-able? .... (2) There appears to be plenty of real-estate, can a Thunderbolt Display be turned into mac and/or pc? ... (3) Any way to upgrade to USB 3.0/3.1?...
I like tinkering with electronics and don't mind the complexities or if necessary getting parts, just wondering if any of these are possible and if so, can you give a clue as to where I can find more info... Thank You.
Mark Karasin - Reply Share
Would like to see a continuation of what it takes to replace the Thunderbolt cable that is attached to the back of the display
Michael Martin - Reply Share
Hi Michael
What happen to your monitor for you to need to replace the cable. It could be solution as to why my monitor has a black screen.
Any help?
Thanks
Fm34b - Reply Share
Does the LCD from an iMac 2009 27” fit into the Thunderbolt Display and make it work?
Aldo B - Reply Share
Past 24 Hours: 9
Past 7 Days: 87
Past 30 Days: 365
All Time: 40,124
