Apple TV 3rd Generation Disassembly
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Apple TV 3rd Generation Disassembly, Open the bottom: step 1, image 1 of 3 Apple TV 3rd Generation Disassembly, Open the bottom: step 1, image 2 of 3 Apple TV 3rd Generation Disassembly, Open the bottom: step 1, image 3 of 3
      • Insert a Jimmy into the left side of the Apple TV, then work your way around the bottom and pull the base off.
      Ask FixBot
    2. Apple TV 3rd Generation Disassembly: step 2, image 1 of 3 Apple TV 3rd Generation Disassembly: step 2, image 2 of 3 Apple TV 3rd Generation Disassembly: step 2, image 3 of 3
      • First, peel off the thermal heat sink.
      • Then, using a Phillips #0 screwdriver, unscrew the 5 screws holding the heat sink.
      Ask FixBot
    3. Apple TV 3rd Generation Disassembly, Unfasten the cables: step 3, image 1 of 3 Apple TV 3rd Generation Disassembly, Unfasten the cables: step 3, image 2 of 3 Apple TV 3rd Generation Disassembly, Unfasten the cables: step 3, image 3 of 3
      • 1. Unhook the Power Supply Cable.
      • 2. Unhook the IR Sensor cable
      • Lift the logic board up with a Spudger.
      Ask FixBot
    4. Apple TV 3rd Generation Disassembly: step 4, image 1 of 1
      • Using a Metal Spudger, lift off the bottom base and power supply.
      Ask FixBot
Cooper Anderson
571 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 415
