Apple TV 2nd Generation Bottom Cover Replacement
    1. Apple TV 2nd Generation Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
      Tool used on this step:
      Metal Spudger
      $2.99
      Buy
      • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
      Ask FixBot
    2. Apple TV 2nd Generation Bottom Cover Replacement: step 2, image 1 of 1
      • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
      Ask FixBot
Areej Bashawiri
246 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 119
All Time: 1,939
