Apple TV 1st Generation AirPort Card Replacement
    1. Apple TV 1st Generation AirPort Card Replacement, Lower Case: step 1, image 1 of 1
      • Flip the Apple TV over so that the bottom of the unit is facing up.
      • You need to remove the rubber base to get access to the screws.
      • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
      • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
      • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
      • The rubber base can tear if the adhesive hasn't been softened enough.
      • Repeat the procedure described above until the rubber base has been completely removed.
      Ask FixBot
    2. Apple TV 1st Generation AirPort Card Replacement: step 2, image 1 of 1
      • Remove the four T10 Torx screws that secure the lower case to the upper case.
      Ask FixBot
    3. Apple TV 1st Generation AirPort Card Replacement: step 3, image 1 of 1
      • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
      • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
      Ask FixBot
    4. Apple TV 1st Generation AirPort Card Replacement: step 4, image 1 of 2 Apple TV 1st Generation AirPort Card Replacement: step 4, image 2 of 2
      • Carefully pull the hard drive data cable straight up from its socket on the logic board.
      • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
      Ask FixBot
    1. Apple TV 1st Generation AirPort Card Replacement, AirPort Card: step 5, image 1 of 1
      • Pry the AirPort antenna cables straight up from their sockets on the logic board.
      Ask FixBot
    2. Apple TV 1st Generation AirPort Card Replacement: step 6, image 1 of 1
      • Remove the single T8 Torx screw securing the AirPort card to the logic board.
      Ask FixBot
    3. Apple TV 1st Generation AirPort Card Replacement: step 7, image 1 of 1
      • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
      Ask FixBot
12 other people completed this guide.
ropel
119 Reputation
2 Guides authored
Cal Poly, Team 18-5, Maness Fall 2009 Member of Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 107
All Time: 14,209
