Apple Studio Display M7649 Inverter Replacement
Views: 8.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
105
All Time:
8,091
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the inverter, a common cause for what looks to be a loss of backlight.
Tools
    1. Apple Studio Display M7649 Inverter Replacement, Stand: step 1, image 1 of 2 Apple Studio Display M7649 Inverter Replacement, Stand: step 1, image 2 of 2
      • Lay the display facing down with the stand away from you.
      • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
      Ask FixBot
    1. Apple Studio Display M7649 Inverter Replacement, Panels: step 2, image 1 of 1
      • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
      Ask FixBot
    2. Apple Studio Display M7649 Inverter Replacement: step 3, image 1 of 1
      • Rotate the display so the legs of the display are now facing you
      • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
      Ask FixBot
    3. Apple Studio Display M7649 Inverter Replacement: step 4, image 1 of 1
      • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
      Ask FixBot
    1. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: step 5, image 1 of 1
      • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
      Ask FixBot
    2. Apple Studio Display M7649 Inverter Replacement: step 6, image 1 of 1
      • Now locate and remove the lone Phillips screw holding the EMI shield to the display
      Ask FixBot
    3. Apple Studio Display M7649 Inverter Replacement: step 7, image 1 of 2 Apple Studio Display M7649 Inverter Replacement: step 7, image 2 of 2
      • Now that the screw has been removed, slide the panel towards your body and lift it out.
      • You may need to remove the clear USB port cover to remove the metal EMI shield.
      Ask FixBot
    1. Apple Studio Display M7649 Inverter Replacement, Inverter: step 8, image 1 of 1
      • Remove these three screws holding the board to the display
      Ask FixBot
    2. Apple Studio Display M7649 Inverter Replacement: step 9, image 1 of 1
      • Remove these five cables connection the inverter to the backlights and logic board.
      • Taking note where they connect to for reassembly
      Ask FixBot
    3. Apple Studio Display M7649 Inverter Replacement: step 10, image 1 of 1
      • Remove and replace the inverter
      Ask FixBot
5 other people completed this guide.
Andrew Tsao
186 Reputation
5 Guides authored
Cal Poly, Team 3-20, Maness Winter 2010 Member of Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 105
All Time: 8,091
