Apple Studio Display M7649 ADC Cable Replacement
Views: 4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
123
All Time:
4,015
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the ADC cable. This cable provides connection to the computer, along with supplying power to the display.
Tools
    1. Apple Studio Display M7649 ADC Cable Replacement, Stand: step 1, image 1 of 2 Apple Studio Display M7649 ADC Cable Replacement, Stand: step 1, image 2 of 2
      • Lay the display facing down with the stand away from you.
      • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
      Ask FixBot
    1. Apple Studio Display M7649 ADC Cable Replacement, Panels: step 2, image 1 of 1
      • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
      Ask FixBot
    2. Apple Studio Display M7649 ADC Cable Replacement: step 3, image 1 of 1
      • Rotate the display so the legs of the display are now facing you
      • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
      Ask FixBot
    3. Apple Studio Display M7649 ADC Cable Replacement: step 4, image 1 of 1
      • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
      Ask FixBot
    1. Apple Studio Display M7649 ADC Cable Replacement, Metal EMI Shield: step 5, image 1 of 1
      • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
      Ask FixBot
    2. Apple Studio Display M7649 ADC Cable Replacement: step 6, image 1 of 1
      • Now locate and remove the lone Phillips screw holding the EMI shield to the display
      Ask FixBot
    3. Apple Studio Display M7649 ADC Cable Replacement: step 7, image 1 of 2 Apple Studio Display M7649 ADC Cable Replacement: step 7, image 2 of 2
      • Now that the screw has been removed, slide the panel towards your body and lift it out.
      • You may need to remove the clear USB port cover to remove the metal EMI shield.
      Ask FixBot
    1. Apple Studio Display M7649 ADC Cable Replacement, USB Port: step 8, image 1 of 1
      • To remove the USB port, remove these four screws holding down the port and metal brackets.
      • There may be a zip tie you need to cut that is attaching the USB unit to the display
      Ask FixBot
    2. Apple Studio Display M7649 ADC Cable Replacement: step 9, image 1 of 1
      • Remove the cable from the logic board that is connecting the USB port.
      Ask FixBot
    3. Apple Studio Display M7649 ADC Cable Replacement: step 10, image 1 of 1
      • Remove the USB port
      Ask FixBot
    1. Apple Studio Display M7649 ADC Cable Replacement, ADC Cable: step 11, image 1 of 1
      • Remove these four screws holding down the base of the swing arm to the display and remove it
      Ask FixBot
    2. Apple Studio Display M7649 ADC Cable Replacement: step 12, image 1 of 1
      • Remove the four screws holding down the ADC cable to the display
      Ask FixBot
    3. Apple Studio Display M7649 ADC Cable Replacement: step 13, image 1 of 1
      • Remove the three connections that connects the ADC assembly to the logic board and screen
      Ask FixBot
    4. Apple Studio Display M7649 ADC Cable Replacement: step 14, image 1 of 1
      • Remove and replace the ADC cable assembly.
      Ask FixBot
3 other people completed this guide.
Andrew Tsao
186 Reputation
5 Guides authored
Cal Poly, Team 3-20, Maness Winter 2010 Member of Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Members
96 Guides authored
1 Guide Comment
What are the two red wires and two black wires ?
Cali Red - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 123
All Time: 4,015
