Apple Studio Display M2454 LCD Main Board Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
110
All Time:
4,545
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The LCD main board is the backbone of the Apple Studio Display M2454. It accepts the information coming from the computer and transmits this data to the screen to form an image. The main board is also wired into the USB ports on the back of the monitor and other circuitry. There are many connections but replacing this board is relatively easy.
    1. Apple Studio Display M2454 LCD Main Board Replacement, LCD Main Board: step 1, image 1 of 1
      • Locate the four hex head screws located on the corners of the back panel.
      • Remove the screws with a 2mm hex screwdriver.
      Ask FixBot
    2. Apple Studio Display M2454 LCD Main Board Replacement: step 2, image 1 of 1
      • Locate the three 2mm hex screws located on the back stand of the monitor.
      • These screws must be removed with the 2mm hex screwdriver in order for the back panel to be removed.
      Ask FixBot
    3. Apple Studio Display M2454 LCD Main Board Replacement: step 3, image 1 of 1
      • Pull the clear back panel cover off.
      • Be sure to feed the cable through the back panel so no damage occurs.
      Ask FixBot
    4. Apple Studio Display M2454 LCD Main Board Replacement: step 4, image 1 of 1
      • Now remove the back panel under the clear cover.
      • Again, feed the cable through the panel so no damage occurs.
      Ask FixBot
    5. Apple Studio Display M2454 LCD Main Board Replacement: step 5, image 1 of 1
      • Remove the phillips head screw holding the back panel spacer with the phillips head screwdriver.
      Ask FixBot
    6. Apple Studio Display M2454 LCD Main Board Replacement: step 6, image 1 of 1
      • Remove the two phillips head screws near the cable attachment with the phillips head screwdriver.
      Ask FixBot
    7. Apple Studio Display M2454 LCD Main Board Replacement: step 7, image 1 of 2 Apple Studio Display M2454 LCD Main Board Replacement: step 7, image 2 of 2
      • To remove the metal plate covering the circuitry you need to push the cover towards the base of the monitor. (First remove any transparent plastic piece on the two USB connectors.)
      • If done correctly the tabs holding the plate should be detached and the plate will easily pop off.
      Ask FixBot
    8. Apple Studio Display M2454 LCD Main Board Replacement: step 8, image 1 of 1
      • Now that the circuitry is exposed the boards can be seen and replaced.
      • The LCD Main Board is the largest board in the center of the device with seven external connections.
      Ask FixBot
    9. Apple Studio Display M2454 LCD Main Board Replacement: step 9, image 1 of 1
      • Locate the four phillips head screws on the corners of the board.
      • Using the phillips head screwdriver, remove the four screws holding the board to the monitor.
      Ask FixBot
    10. Apple Studio Display M2454 LCD Main Board Replacement: step 10, image 1 of 1
      • Remove the four braided connections simply by pushing the side of the connectors in and pull out.
      Ask FixBot
    11. Apple Studio Display M2454 LCD Main Board Replacement: step 11, image 1 of 1
      • Remove the other two connectors by raising the tab on each either by hand or using a flat ended tool as shown.
      • Then gently pull away from the board to release tabs.
      • The tabs can easily break off, be extra careful.
      Ask FixBot
    12. Apple Studio Display M2454 LCD Main Board Replacement: step 12, image 1 of 1
      • Remove the final black connector by pressing down on the back of the tab on the connector and then pull away from the board.
      • Be careful when holding onto the board while removing this connector or you risk pulling the board away too quickly and damaging the connector.
      Ask FixBot
    13. Apple Studio Display M2454 LCD Main Board Replacement: step 13, image 1 of 1
      • With all the connectors removed the board can be lifted away.
      • Now the new board can be attached by following the previous steps in reverse.
      Ask FixBot
Finish Line
Dylan Perry
177 Reputation
5 Guides authored
Cal Poly, Team 13-27, Maness Winter 2010 Member of Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 110
All Time: 4,545
