Apple Studio Display M2454 CCFL Inverter Replacement
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: step 1, image 1 of 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: step 1, image 2 of 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
    Ask FixBot
  2. Apple Studio Display M2454 CCFL Inverter Replacement: step 2, image 1 of 2 Apple Studio Display M2454 CCFL Inverter Replacement: step 2, image 2 of 2
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • Remove the transparent plastic around the USB ports.
    • Push metal backing toward back of monitor to release its clips and pull away.
    Ask FixBot
  3. Apple Studio Display M2454 CCFL Inverter Replacement: step 3, image 1 of 2 Apple Studio Display M2454 CCFL Inverter Replacement: step 3, image 2 of 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
    Ask FixBot
  4. Apple Studio Display M2454 CCFL Inverter Replacement: step 4, image 1 of 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
    Ask FixBot
  5. Apple Studio Display M2454 CCFL Inverter Replacement: step 5, image 1 of 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
    Ask FixBot
  6. Apple Studio Display M2454 CCFL Inverter Replacement: step 6, image 1 of 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
    Ask FixBot
Finish Line
Dylan Perry
177 Reputation
5 Guides authored
Cal Poly, Team 13-27, Maness Winter 2010 Member of Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 7,416
