Apple Powerbook 540c Disassembly
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
98
All Time:
2,086
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
      • Slide the release button toward you and pull out the main battery from the right battery bay of the computer.
      • Repeat the procedure for the second battery, if installed, in the left battery bay of the computer.
      • If a PCMCIA card is installed, eject the card first, then remove the PCMCIA card cage from the left battery bay.
      Ask FixBot
      • Using a T8 torx driver, remove the middle two bottom housing screws
      • Using a small flat-blade screwdriver, lift the front of the keyboard and pull it forward slightly.
      • Rotate the keyboard so that it is perpendicular to the top cover.
      • Release the locking tabs on the two keyboard cable connectors and disconnect the cables from the motherboard
      • Lift off the keyboard.
      Ask FixBot
      • Using a T8 torx driver, remove the hard drive mounting screw.
      • Using a small flat-blade screwdriver, pry up the front of the hard drive and slide it forward.
      • Lift the drive partway out of the unit and disconnect the hard drive cable.
      • Remove the hard drive.
      Ask FixBot
      • If you are replacing the hard drive, remove the four screws and remove the hard drive bracket and insulator.
      Ask FixBot
      • Using a T-8 torx driver, remove the two floppy drive screws.
      • Using a small flat-blade screwdriver, pry up the cable end of the floppy drive and slide the drive to the left.
      • Slide the drive forward slightly and lift it partway out of the unit.
      • Disconnect the floppy drive cable from the motherboard and remove the drive.
      • If you are replacing the floppy drive or floppy drive cable, release the locking tabs and disconnect the cable from the drive.
      Ask FixBot
      • Open the unit and rotate the display assembly as far back as it will go.
      • Using a flat-blade screwdriver and your fingers, press in on both sides of the wide end of the right clutch cover and release the two front latches.
      • Rotate the clutch cover up, release the third latch, and remove the cover.
      • Repeat for the other clutch cover.
      Ask FixBot
      • Using a small flat-blade screwdriver, pry up the display access cover at the three slots in the front of the cover.
      • Remove the display access cover.
      Ask FixBot
      • Disconnect the interconnect to logic board cable.
      • Using a T-8 torx driver, remove the two display mounting screws.
      • Slide the display assembly to the left so that the right clutch clears the loop of the interconnect to logic board cable.
      • Remove the display assembly.
      Ask FixBot
      • Using a T-8 torx driver, remove the two rear panel screws.
      • Pull the center base cover forward slightly and slide it to the right to release the two screw carriers.
      • Remove the center base cover.
      Ask FixBot
      • Rotate the feet to the up position.
      • Using a T-8 torx driver, remove the screw located under each foot.
      • Remove the four screws at the front edge of the bottom case
      • Remove the remaining screw on the inside top edge of the case.
      • Carefully lift and rotate the top case toward you and disconnect the track pad cable from the motherboard.
      • Remove the interconnect to logic board cable from the opening for the right clutch.
      • Remove the top case.
      Ask FixBot
      • With a T8 Torx driver, remove the three mounting screws on the EMI shield.
      • Using a small flat-blade screwdriver, pry up and remove the daughterboard EMI shield.
      Ask FixBot
      • Remove the plastic retainer bar.
      • You will need an IC extractor. I do not recommend using a flat head screwdriver
      • Place the legs of the IC extractor in the notches at the end of the daughterboard and pull up.
      Ask FixBot
      • Remove the two screws from the plastic retainer bar.
      • Gently but firmly slide the plastic retainer bar away from the RAM card to release it.
      • Insert the IC puller along the two notches on either side of the RAM card.
      • Gripping the IC puller firmly, pull straight up to remove the RAM card.
      Ask FixBot
      • To remove the modem card, place the legs of the IC extractor in the notches at the end of the board and pull up.
      Ask FixBot
      • Disconnect the interconnect to logic board cable from the motherboard and remove the cable.
      Ask FixBot
      • Using a T-8 torx driver, remove the three right side panel mounting screw.
      • Lift the panel slightly, slide it back, and remove it from the CPU stiffener.
      • Using a T-8 torx driver, remove the three left side-panel mounting screws.
      • Slide the panel to the left and remove it from the CPU stiffener.
      Ask FixBot
      • Unlatch the left side panel from the back panel.
      • Lift the CPU stiffener straight off the unit.
      Ask FixBot
      • Remove the motherboard mounting screw and standoff.
      • Carefully pry the motherboard from the positioning peg located below the standoff.
      • Slide the board forward and lift it out.
      Ask FixBot
      • Turn over the motherboard.
      • Disconnect the hard drive cable from the motherboard.
      Ask FixBot
      • Carefully disconnect the microphone cable from the interconnect board.
      • Using a small flat-blade screwdriver, pry up and remove the microphone assembly.
      Ask FixBot
      • Using a small flat-blade screwdriver, pry up and remove the backup battery cover.
      • Carefully disconnect the backup battery cable.
      • Remove the cable from the cable guides.
      • Pry up and remove the backup battery and cable.
      Ask FixBot
      • Using a T-8 torx driver, remove the front two mounting screws.
      • Disconnect the trackpad cable assembly and remove it from the unit.
      • Using a T-8 torx driver, remove the remaining two mounting screws
      • Pry up and remove the trackpad actuator assembly.
      • With your fingers, push up from underneath the trackpad logic board and remove it from the top case
      Ask FixBot
      • Disconnect the speaker cable from the interconnect board.
      • Remove the bottom two bezel mounting screws.
      • Pry off the two rubber bumpers and remove the top two bezel mounting screws.
      • Pull the display bezel forward and lift it off the rear housing.
      Ask FixBot
      • Remove the four mounting screws.
      • Disconnect the backlight cable from the inverter board.
      • Lift the display from the rear housing.
      Ask FixBot
      • Remove the two mounting screws
      • Disconnect the interconnect to inverter cable and the backlight cable.
      • Remove the inverter board.
      Ask FixBot
      • Disconnect the interconnect to display cable and the interconnect to inverter cable.
      • Remove the two mounting screws.
      • Remove the interconnect board.
      Ask FixBot
      • Disconnect the interconnect to inverter cable from the interconnect and inverter boards.
      • Remove the cable from the back housing.
      Ask FixBot
      • Disconnect the interconnect to display cable from the back of the display.
      • Remove the cable.
      Ask FixBot
      • Remove the mounting screw for the right clutch and remove the clutch.
      • Repeat for the left clutch
      Ask FixBot
Luke
1,613 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 98
All Time: 2,086
