Apple Powerbook 5300 Battery Replacement
    1. Apple Powerbook 5300 Battery Replacement, Battery: step 1, image 1 of 2 Apple Powerbook 5300 Battery Replacement, Battery: step 1, image 2 of 2
      • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
      • Press the battery removal latch located on the right side of the front panel.
      • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
      • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
      Ask FixBot
Alex Wineteer
154 Reputation
1 Guide authored
Cal Poly, Team 25-30, Garner Spring 2011 Member of Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,690
