Apple Powerbook 520/540 General Disassembly
    1. Apple Powerbook 520/540 General Disassembly, Case: step 1, image 1 of 2 Apple Powerbook 520/540 General Disassembly, Case: step 1, image 2 of 2
      • Turn computer over.
      • Remove battery expansion cover and battery.
      Ask FixBot
    2. Apple Powerbook 520/540 General Disassembly: step 2, image 1 of 1
      • With monitor hinge at the bottom, remove the two top center screws.
      Ask FixBot
    3. Apple Powerbook 520/540 General Disassembly: step 3, image 1 of 1
      • Remove top left and top right screws.
      Ask FixBot
    4. Apple Powerbook 520/540 General Disassembly: step 4, image 1 of 1
      • Remove middle left and middle right screws.
      Ask FixBot
    5. Apple Powerbook 520/540 General Disassembly: step 5, image 1 of 1
      • Open computer kickstands.
      • Remove screws underneath each kickstand.
      Ask FixBot
    6. Apple Powerbook 520/540 General Disassembly: step 6, image 1 of 1
      • Lift keyboard from bottom and take out of shell.
      Ask FixBot
    7. Apple Powerbook 520/540 General Disassembly: step 7, image 1 of 3 Apple Powerbook 520/540 General Disassembly: step 7, image 2 of 3 Apple Powerbook 520/540 General Disassembly: step 7, image 3 of 3
      • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
      • Removing both ribbon cables from the motherboard will leave the clamps like so.
      • From here you can access the logic board, hard drive, and floppy drive.
      Ask FixBot
11 other people completed this guide.
Mark McNeff
515 Reputation
2 Guides authored
2 Guide Comments
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Reply Share
Thanks been trying to fix this for a long time
Luke - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 61
All Time: 8,088
