Apple Powerbook 520 Hard Drive Replacement
    1. Apple Powerbook 520 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • After completing the initial disassembly, you may proceed to hard drive replacement.
      Ask FixBot
    2. Apple Powerbook 520 Hard Drive Replacement: step 2, image 1 of 2 Apple Powerbook 520 Hard Drive Replacement: step 2, image 2 of 2
      • First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame.
      • Next, you will remove the mounting frame and the plastic shield.
      Ask FixBot
    3. Apple Powerbook 520 Hard Drive Replacement: step 3, image 1 of 1
      • You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
      Ask FixBot
    4. Apple Powerbook 520 Hard Drive Replacement: step 4, image 1 of 1
      • Carefully, pry the ribbon away from the pins.
      Ask FixBot
    5. Apple Powerbook 520 Hard Drive Replacement: step 5, image 1 of 1
      • Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
      Ask FixBot
4 other people completed this guide.
Tyler
148 Reputation
2 Guides authored
Cal Poly, Team 20-66, Walters Spring 2011 Member of Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 5,814
