Apple PowerBook G3 400 Keyboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
99
All Time:
2,352
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the keyboard in a simple step by step process.
    1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      Ask FixBot
    2. Apple PowerBook G3 400 Keyboard Replacement: step 2, image 1 of 1
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      Ask FixBot
    3. Apple PowerBook G3 400 Keyboard Replacement: step 3, image 1 of 1
      • Your computer should look approximately like this.
      Ask FixBot
Byron Hoefer
70 Reputation
2 Guides authored
Cal Poly, Team 4-2, Regan Spring 2011 Member of Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 99
All Time: 2,352
