Apple PowerBook G3 400 Display Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
43
All Time:
2,253
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
You will do this after you have taken out the hard drive.
Tools
    1. Apple PowerBook G3 400 Display Replacement, Keyboard: step 1, image 1 of 1
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      Ask FixBot
    2. Apple PowerBook G3 400 Display Replacement: step 2, image 1 of 1
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      Ask FixBot
    3. Apple PowerBook G3 400 Display Replacement: step 3, image 1 of 1
      • Your computer should look approximately like this.
      Ask FixBot
    1. Apple PowerBook G3 400 Display Replacement, RAM: step 4, image 1 of 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
      • Lift the heat shield up and toward you.
      Ask FixBot
    2. Apple PowerBook G3 400 Display Replacement: step 5, image 1 of 1
      • Pull the PRAM battery cable vertically upward to disconnect it.
      • Remove the battery by pulling up and to the left.
      Ask FixBot
    3. Apple PowerBook G3 400 Display Replacement: step 6, image 1 of 1
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      • Remove the long silver Phillips #1 screw from the heat sink.
      Ask FixBot
    4. Apple PowerBook G3 400 Display Replacement: step 7, image 1 of 1
      • Lift up the heat sink unit from the left side and remove.
      Ask FixBot
    5. Apple PowerBook G3 400 Display Replacement: step 8, image 1 of 1
      • Lift the processor on the right side and pull directly up.
      • The RAM chips should be in the slots on the processor.
      Ask FixBot
    6. Apple PowerBook G3 400 Display Replacement: step 9, image 1 of 1
      • After removing the RAM, your laptop should now look like this.
      Ask FixBot
    1. Apple PowerBook G3 400 Display Replacement, Hard Drive: step 10, image 1 of 1
      • Locate the orange tab, which should be just left of the hard-drive.
      • You must disconnect this orange tab from the logic board to enable the next step.
      • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
      Ask FixBot
    2. Apple PowerBook G3 400 Display Replacement: step 11, image 1 of 1
      • Grab the plastic strip shown here and gently remove, pulling up and left.
      • Pull left to avoid the hard drive catching the casing.
      Ask FixBot
    3. Apple PowerBook G3 400 Display Replacement: step 12, image 1 of 1
      • Once you have removed the hard-drive, your laptop should like this.
      Ask FixBot
    1. Apple PowerBook G3 400 Display Replacement, Modem: step 13, image 1 of 1
      • Remove the single black Torx screw from the modem.
      • Remove the black rectangle that is being held on by the one Torx screw.
      Ask FixBot
    2. Apple PowerBook G3 400 Display Replacement: step 14, image 1 of 1
      • Using your fingers, lift the modem from the socket it is plugged into.
      Ask FixBot
    3. Apple PowerBook G3 400 Display Replacement: step 15, image 1 of 1
      • Disconnect the cable that is attached to the end of the modem to remove the modem.
      Ask FixBot
    1. Apple PowerBook G3 400 Display Replacement, Display: step 16, image 1 of 1
      • Your computer will look approximately like this.
      Ask FixBot
    2. Apple PowerBook G3 400 Display Replacement: step 17, image 1 of 1
      • Push the display back.
      • Put your index finger under the power button and gently pull the clutch cover back.
      • Repeat for the left side.
      Ask FixBot
    3. Apple PowerBook G3 400 Display Replacement: step 18, image 1 of 1
      • Lift the clutch cover up and off. Pull it towards yourself.
      Ask FixBot
    4. Apple PowerBook G3 400 Display Replacement: step 19, image 1 of 1
      • Disconnect the display cable from the logic board.
      Ask FixBot
    5. Apple PowerBook G3 400 Display Replacement: step 20, image 1 of 1
      • Remove the Torx screw that holds the display cable.
      • Pull out thick display inverter board by pulling it up and out. Two tabs will be holding it in place, you need to get pass these to pull the board free.
      Ask FixBot
    6. Apple PowerBook G3 400 Display Replacement: step 21, image 1 of 1
      • Disconnect the white inverter cable. Pull it towards the left.
      Ask FixBot
    7. Apple PowerBook G3 400 Display Replacement: step 22, image 1 of 1
      • Disconnect the inverter plug by pulling it up from the logib board.
      Ask FixBot
    8. Apple PowerBook G3 400 Display Replacement: step 23, image 1 of 1
      • Turn the laptop around.
      • Open the port door.
      • Remove the four Torx screws.
      Ask FixBot
    9. Apple PowerBook G3 400 Display Replacement: step 24, image 1 of 1
      • Turn the laptop so the front faces you.
      • Pull the black Airport antenna up.
      Ask FixBot
    10. Apple PowerBook G3 400 Display Replacement: step 25, image 1 of 1
      • Pull the display up as you hold it firmly with both hands.
      Ask FixBot
Isabelle
11 Reputation
1 Guide authored
Cal Poly, Team 4-2, Regan Spring 2011 Member of Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 43
All Time: 2,253
