Up to 20% off select tools
Apple Magic Keyboard Keys Repair
Views: 7.8K
View statistics:
Past 24 Hours:
11
Past 7 Days:
108
Past 30 Days:
403
All Time:
7,824
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 day
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
      • Remove the batteries.
      • Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
      • Remove the small screw.
      Ask FixBot
      • Use a flat blunt tool to loosen the ribbon cable clamp. To do this, pull the front part away from the rear part.
      • Pull out the ribbon cable.
      Ask FixBot
      • Put the batteries back in (without screwing the cover on).
      • Push in the batteries to release the circuit board assembly.
      • Carefully pull out the circuit board assembly. Pay attention to the ribbon cable.
      Ask FixBot
      • Soak the keyboard in alcohol (methylated spirits). It should be completely covered. Use an airtight container.
      • Keep moving the container to get the liquid everywhere.
      • Wait 24 hours
      Ask FixBot
      • Take the keyboard out of the liquid and shake it out well.
      • CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
      • The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
      • Let the keyboard dry well. To speed up the process, you can put it into the sun.
      Ask FixBot
      • Put the parts back together in reverse order. When installing the circuit board unit, make sure that you pull the ribbon cable to the side.
      Ask FixBot
Finish Line
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Sebastian Reindl
268 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 108
Past 30 Days: 403
All Time: 7,824
