Apple Magic Keyboard 2 A2450 Motherboard Replacement
  1. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: step 1, image 1 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: step 1, image 2 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: step 1, image 3 of 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
    Ask FixBot
  2. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
    Ask FixBot
  3. Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 3, image 1 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 3, image 2 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 3, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
    Ask FixBot
  4. Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 4, image 1 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 4, image 2 of 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: step 4, image 3 of 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
    Ask FixBot
Brayden Devenport
139 Reputation
1 Guide authored
IUPUI, Team 3-2, Harley Spring 2024 Member of IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 34
All Time: 786
