Apple Magic Keyboard 2 A2450 Lightning Port Replacement
  1. Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: step 1, image 1 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: step 1, image 2 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: step 1, image 3 of 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
    Ask FixBot
  2. Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: step 2, image 1 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: step 2, image 2 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: step 2, image 3 of 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
    Ask FixBot
  3. Apple Magic Keyboard 2 A2450 Lightning Port Replacement: step 3, image 1 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement: step 3, image 2 of 3 Apple Magic Keyboard 2 A2450 Lightning Port Replacement: step 3, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
    Ask FixBot
Alex
225 Reputation
2 Guides authored
IUPUI, Team 3-2, Harley Spring 2024 Member of IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Members
3 Guides authored
2 Guide Comments
I am glad I found this post. I broke the cable from the lighting port on the Apple Keyboard 2 A2450 (touch id, not numeric pad) and would like to find a new lightning port and cable. Can you point me to a place where I can buy this please. I think I need to lighting port and the cable because it seems that the cable cannot be removed from the lighting port.
Peter Saunders - Reply Share
i also would need the lightning port for the Appel key board can we buy it from you side?
Bernhelm - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 38
All Time: 643
