Apple Magic Keyboard 2 A2450 Keyboard Replacement
    1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: step 1, image 1 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: step 1, image 2 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: step 1, image 3 of 3
      • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
      • The plastic should be a bit too warm to touch comfortably, but not hot.
      • Insert an opening pick in the gap between the lower case and chassis.
      • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
      • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
      • Remove the lower case.
      Ask FixBot
    1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: step 2, image 3 of 3
      • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
      • Use tweezers to disconnect the battery motherboard connection.
      • Remove the midframe.
      Ask FixBot
    2. Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 3, image 1 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 3, image 2 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 3, image 3 of 3
      • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
      • Use tweezers to remove the Lighting port from the motherboard.
      Ask FixBot
    3. Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 4, image 1 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 4, image 2 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 4, image 3 of 3
      • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
      • Remove the tape covering the ribbon cable on the top half of the motherboard.
      • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
      Ask FixBot
    4. Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 5, image 1 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 5, image 2 of 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 5, image 3 of 3
      • Use a T3 Torx screwdriver to remove the single 3 mm screw that secures the assembly to the frame.
      • Use tweezers to unplug the power switch from the case. Pull horizontally on the entire assembly to remove the switch from the keyboard.
      Ask FixBot
    5. Apple Magic Keyboard 2 A2450 Keyboard Replacement: step 6, image 1 of 1
      • Replace the keyboard.
      Ask FixBot
Alex
225 Reputation
2 Guides authored
IUPUI, Team 3-2, Harley Spring 2024 Member of IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 49
Past 30 Days: 175
All Time: 3,548
