Up to 20% off select tools
Apple EarPods Disassembly
Views: 55K
View statistics:
Past 24 Hours:
8
Past 7 Days:
115
Past 30 Days:
596
All Time:
55,195
Comments: 1
1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Use this guide to help you optimize audio function from your Apple EarPods.
    1. Apple EarPods Disassembly, Tools You Need: step 1, image 1 of 2 Apple EarPods Disassembly, Tools You Need: step 1, image 2 of 2
      • X-ACTO Knife
      • Tweezer
      • Triangle Paddle
      • Alcohol
      • Cotton Swabs
      Ask FixBot
    2. Apple EarPods Disassembly, Opening Earpod: step 2, image 1 of 2 Apple EarPods Disassembly, Opening Earpod: step 2, image 2 of 2
      • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
      Ask FixBot
    3. Apple EarPods Disassembly, Cleaning Inside and Out: step 3, image 1 of 1
      • Soak one side of a cotton swab with alcohol
      • Clean inner and outer pod using swab soaked in alcohol
      Ask FixBot
    4. Apple EarPods Disassembly, Cleaning the Speaker Cone: step 4, image 1 of 1
      • Carefully clean the speaker cone using cotton swab
      • Once clean, reattach the earbud
      Ask FixBot
    5. Apple EarPods Disassembly, Removing the Grill: step 5, image 1 of 2 Apple EarPods Disassembly, Removing the Grill: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully remove grill out of both earbuds using tweezers
      • Take precautions not to bend grill excessively
      Ask FixBot
    6. Apple EarPods Disassembly, Grill Polishing: step 6, image 1 of 1
      • Clean grill with cotton swab soaked in alcohol
      • Remove any build up of wax or sweat
      Ask FixBot
    7. Apple EarPods Disassembly, Placing Grill Back: step 7, image 1 of 2 Apple EarPods Disassembly, Placing Grill Back: step 7, image 2 of 2
      • Once the grill is clean, place the grill back inside of the apple earbuds
      Ask FixBot
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
9 other people completed this guide.
Author
with
Eduardo Gonzalez
425 Reputation
1 Guide authored
1 Guide Comment
When I re assemble they won’t stay closed. Do I glue them back together?
Patrick Appleby - Reply Share
Past 24 Hours: 8
Past 7 Days: 115
Past 30 Days: 596
All Time: 55,195
