Apple Cinema Display M8149 USB Port Replacement
    1. Apple Cinema Display M8149 USB Port Replacement, USB Port: step 1, image 1 of 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: step 1, image 2 of 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: step 1, image 3 of 3
      • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
      • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
      • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
      • Remove the back foot from the hinge mount by gently pulling it upwards.
      Ask FixBot
    2. Apple Cinema Display M8149 USB Port Replacement: step 2, image 1 of 3 Apple Cinema Display M8149 USB Port Replacement: step 2, image 2 of 3 Apple Cinema Display M8149 USB Port Replacement: step 2, image 3 of 3
      • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
      • Once the screws are removed, lift the back plate off of the display.
      • Completely remove the back plate and set it aside.
      Ask FixBot
    3. Apple Cinema Display M8149 USB Port Replacement: step 3, image 1 of 1
      • Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
      Ask FixBot
    4. Apple Cinema Display M8149 USB Port Replacement: step 4, image 1 of 1
      • Unplug the USB cable connector from the screen box.
      Ask FixBot
    5. Apple Cinema Display M8149 USB Port Replacement: step 5, image 1 of 2 Apple Cinema Display M8149 USB Port Replacement: step 5, image 2 of 2
      • Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
      Ask FixBot
Kyle Suguitan
21 Reputation
1 Guide authored
Cal Poly, Team 10-41, Forte Spring 2011 Member of Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 42
All Time: 5,117
