Apple AirPort Extreme Model A1034 Internet Card Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
103
All Time:
5,864
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
    1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: step 1, image 1 of 1
      • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
      Ask FixBot
    2. Apple AirPort Extreme Model A1034 Internet Card Replacement: step 2, image 1 of 1
      • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
      Ask FixBot
    3. Apple AirPort Extreme Model A1034 Internet Card Replacement: step 3, image 1 of 2 Apple AirPort Extreme Model A1034 Internet Card Replacement: step 3, image 2 of 2
      • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
      Ask FixBot
    4. Apple AirPort Extreme Model A1034 Internet Card Replacement: step 4, image 1 of 1
      • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
      Ask FixBot
    1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: step 5, image 1 of 1
      • Remove four 1mm phillips screws from the bottom.
      Ask FixBot
    2. Apple AirPort Extreme Model A1034 Internet Card Replacement: step 6, image 1 of 1
      • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
      • To remove the AirPort card, gently pull the plastic tab horizontally.
      Ask FixBot
4 other people completed this guide.
Michael Garcia
417 Reputation
5 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
84 Guides authored
1 Guide Comment
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 103
All Time: 5,864
