Up to 20% off select tools
Apex Tablet 7 Camera Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
84
All Time:
1,016
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the camera for the Apex Tablet 7. Use this guide if your tablet has a damaged or malfunctioning camera. You should have a replacement camera and be prepared to remove your old camera.
    1. Apex Tablet 7 Camera Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      Ask FixBot
    2. Apex Tablet 7 Camera Replacement: step 2, image 1 of 2 Apex Tablet 7 Camera Replacement: step 2, image 2 of 2
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      Ask FixBot
    3. Apex Tablet 7 Camera Replacement: step 3, image 1 of 2 Apex Tablet 7 Camera Replacement: step 3, image 2 of 2
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      Ask FixBot
    4. Apex Tablet 7 Camera Replacement: step 4, image 1 of 1
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      Ask FixBot
    5. Apex Tablet 7 Camera Replacement: step 5, image 1 of 1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      Ask FixBot
    1. Apex Tablet 7 Camera Replacement, Camera: step 6, image 1 of 2 Apex Tablet 7 Camera Replacement, Camera: step 6, image 2 of 2
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      Ask FixBot
    2. Apex Tablet 7 Camera Replacement: step 7, image 1 of 1
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      Ask FixBot
    3. Apex Tablet 7 Camera Replacement: step 8, image 1 of 1
      • Carefully remove the cable from the circuit by pulling it straight out.
      Ask FixBot
    4. Apex Tablet 7 Camera Replacement: step 9, image 1 of 1
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      Ask FixBot
To place the new part and reassemble your device, follow these instructions in reverse order.
Author
with
Steven Gutzwiller
480 Reputation
3 Guides authored
Baylor, Team 2-2, Grigsby Spring 2015 Member of Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 84
All Time: 1,016
