Up to 20% off select tools
Apex Tablet 7 Back Panel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
87
All Time:
1,363
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide will show you how to open the back panel. This will allow the user to gain access to the device components and is necessary for most replacements and repairs for the Apex Tablet 7.
    1. Apex Tablet 7 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      Ask FixBot
    2. Apex Tablet 7 Back Panel Replacement: step 2, image 1 of 2 Apex Tablet 7 Back Panel Replacement: step 2, image 2 of 2
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      Ask FixBot
    3. Apex Tablet 7 Back Panel Replacement: step 3, image 1 of 2 Apex Tablet 7 Back Panel Replacement: step 3, image 2 of 2
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      Ask FixBot
    4. Apex Tablet 7 Back Panel Replacement: step 4, image 1 of 1
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      Ask FixBot
    5. Apex Tablet 7 Back Panel Replacement: step 5, image 1 of 1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      Ask FixBot
2 other people completed this guide.
Author
with
Steven Gutzwiller
480 Reputation
3 Guides authored
Baylor, Team 2-2, Grigsby Spring 2015 Member of Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 87
All Time: 1,363
