Up to 20% off select tools
Apex TM772 Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
82
All Time:
546
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Instructions for replacing a broken or damage camera component.
    1. Apex TM772 Camera Replacement, Casing: step 1, image 1 of 1
      • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
      Ask FixBot
    2. Apex TM772 Camera Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Moving along the seam continue to pry the case apart.
      • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
      Ask FixBot
    3. Apex TM772 Camera Replacement: step 3, image 1 of 1
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      Ask FixBot
    1. Apex TM772 Camera Replacement, Front Camera: step 4, image 1 of 1
      Buy
      • The front camera is located at the top right as looking inside the device.
      • With tweezers or your fingers remove the tape covering the camera’s pin connector.
      Ask FixBot
    2. Apex TM772 Camera Replacement: step 5, image 1 of 1
      • With tweezers, flip the black latch to open the pin connector and remove the cable.
      Ask FixBot
Author
with
Doran Van Bemmel
601 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 82
All Time: 546
