Aorus x7 v2 Fan Assembly Replacement
  1. Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: step 1, image 1 of 3 Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: step 1, image 2 of 3 Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: step 1, image 3 of 3
    • Flip the laptop over.
    • Unscrew the 12 screws holding on the bottom cover.
    • Take off the bottom cover.
    • Remove the 12 screws from the heat sink.
    Ask FixBot
  2. Aorus x7 v2 Fan Assembly Replacement: step 2, image 1 of 3 Aorus x7 v2 Fan Assembly Replacement: step 2, image 2 of 3 Aorus x7 v2 Fan Assembly Replacement: step 2, image 3 of 3
    • Remove the heat sinks one by one.
    Ask FixBot
  3. Aorus x7 v2 Fan Assembly Replacement: step 3, image 1 of 3 Aorus x7 v2 Fan Assembly Replacement: step 3, image 2 of 3 Aorus x7 v2 Fan Assembly Replacement: step 3, image 3 of 3
    • Unscrew the six screws from the right fan.
    • Unscrew the six screws from the left fan.
    • Locate the connection plug for the fan to the motherboard and disconnect the left fan connector.
    Ask FixBot
  4. Aorus x7 v2 Fan Assembly Replacement: step 4, image 1 of 3 Aorus x7 v2 Fan Assembly Replacement: step 4, image 2 of 3 Aorus x7 v2 Fan Assembly Replacement: step 4, image 3 of 3
    • Disconnect the right fan connector.
    • Carefully lift up the left and right fans.
    • Set the fans to the side before installing new fans.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order using new left and right fans.
Alexis Hernandez Jimenez
601 Reputation
5 Guides authored
Gateway, Team 1-4, Pee Fall 2022 Member of Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 1,229
