Up to 20% off select tools
Anki Vector Belts Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
1,985
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Should your Anki Vector go over any rough terrain or just accumulate wear over time, you will need to replace its belts.
This guide will help you if the Anki Vector’s wheel belts have become visibly damaged or too stiff to allow proper movement.
You will not need any special equipment for this guide.
    1. Anki Vector Belts Replacement, Belts: step 1, image 1 of 1
      • Raise Vector's arms above his head.
      Ask FixBot
    2. Anki Vector Belts Replacement: step 2, image 1 of 2 Anki Vector Belts Replacement: step 2, image 2 of 2
      • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
      • Repeat on the other side.
      Ask FixBot
Author
with
Shay Takei
1,864 Reputation
5 Guides authored
Cal Poly, Team S2-G6, Maness Spring 2019 Member of Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Members
60 Guides authored
1 Guide Comment
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 1,985
