Introduction
Is your Anker Soundcore Space Q45 power button stuck or not working, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few easy steps.
Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
Clips at 3 o'clock, 7 o'clock and 11 o'clock
Image shows right headphone, battery is in left.
Remove two screws from the motherboard with a Phillips screwdriver.
Remove the motherboard from the headphones.
Use a soldering iron to desolder the contacts connected to the three buttons on the bottom left-hand side of the motherboard.
1 Guide Comment
guide shows how to replace the Play button on the right side of the head phones and the left side is the side with the power button and it seems like you have to disconnect the usbc ribbon cable for right side before you can do step 2
