Anker Soundcore Space Q45 Bluetooth Module Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
106
All Time:
1,231
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Is your Anker Soundcore Space Q45 bluetooth not connecting to your device, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few easy steps.
Tools
    1. Anker Soundcore Space Q45 Bluetooth Module Replacement, Plastic Covering: step 1, image 1 of 1
      • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
      • Clips at 3 o'clock, 7 o'clock and 11 o'clock
      • Image shows right headphone, battery is in left.
      Ask FixBot
    2. Anker Soundcore Space Q45 Bluetooth Module Replacement: step 2, image 1 of 2 Anker Soundcore Space Q45 Bluetooth Module Replacement: step 2, image 2 of 2
      • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
      Ask FixBot
    1. Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: step 3, image 1 of 2 Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: step 3, image 2 of 2
      • Remove two screws from the motherboard with a Phillips screwdriver.
      • Remove the motherboard from the headphones.
      Ask FixBot
    1. Anker Soundcore Space Q45 Bluetooth Module Replacement, Bluetooth Module: step 4, image 1 of 1
      • Use a soldering iron to desolder the connection from the Bluetooth receiver.
      Ask FixBot
Benjamin daCosta
752 Reputation
5 Guides authored
4 Guide Comments
please tell me the model of this microcircuit chip
Мидхат Миннурович - Reply Share
I have the sane question.. what is that chip??!! anyone???
GJN - Reply Share
answering myself and others out there who have their headphones stopped charging..its not the bluetooth chip.. its an IC chip..this seems to be a common problem.. the chip is ETA40543, and its not very commonly available, but you can find it on Aliexpress, about 1$ a piece.
GJN - Reply Share
mine was the GigaDevice 25L064ESIG flash chip, not bluetooth
Luis Miranda Bojorquez - Reply Share
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 106
All Time: 1,231
