Anker Soundcore Space Q45 Battery Replacement
  1. Anker Soundcore Space Q45 Battery Replacement, Plastic Covering: step 1, image 1 of 1
    • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
    • Clips at 3 o'clock, 7 o'clock and 11 o'clock
    • Image shows right headphone, battery is in left.
    Ask FixBot
  2. Anker Soundcore Space Q45 Battery Replacement: step 2, image 1 of 2 Anker Soundcore Space Q45 Battery Replacement: step 2, image 2 of 2
    • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
    Ask FixBot
  3. Anker Soundcore Space Q45 Battery Replacement, Battery: step 3, image 1 of 2 Anker Soundcore Space Q45 Battery Replacement, Battery: step 3, image 2 of 2
    • Gently pull out battery to USB C ribbon connector from circuit board
    Ask FixBot
  4. Anker Soundcore Space Q45 Battery Replacement: step 4, image 1 of 2 Anker Soundcore Space Q45 Battery Replacement: step 4, image 2 of 2
    • Pull directly up on the battery to release it from the tape holding it in place.
    • Battery terminals must be de-soldered to remove fully
    Ask FixBot
    • Battery dimentions - 35mm x 25mm x 6mm 750-800mah 3.7v
    Ask FixBot
  5. Anker Soundcore Space Q45 Battery Replacement: step 6, image 1 of 1
    • Replacing charging ribbon is tricky, use tweezers to reach through square hole and reconnect
    Ask FixBot
5 other people completed this guide.
Benjamin daCosta
734 Reputation
5 Guides authored
6 Guide Comments
Hi. The microphone quality of Anker Q45 is terrible. Do you think it is possible to replace de microphone for a better one?
Perry Picoli - Reply Share
What battery size is that?
Drulius T - Reply Share
Can you show a close up shot of battery? I want to identify its size and other specs...
Steven - Reply Share
What battery model?
Benjamin Fisher - Reply Share
Look for a 632832, but you might have trouble acquiring a single unit, unless you're okay with waiting a month or two with aliexpress shipping
WannabeSpaceman - Reply Share
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 200
All Time: 5,090
