Anker Soundcore Space One Ear Pad Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
23
Past 7 Days:
97
Past 30 Days:
541
All Time:
3,426
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Do your headphones feel uncomfortable when you wear them, or look worn out or dirty? If so, here's the guide to change out the ear pads in your Anker Soundcore Space One headphones.
Headphone earpads are the cushioned coverings that fit over the earpieces of headphones. They serve multiple functions, including comfort and noise isolation. Worn-out or dirty ear pads can become lined with tears, have sound leakage, and have a loss of comfort.
Tools
  • Spudger
    4.9
  • Metal Spudger
    $2.99
    4.9
    Optional
    1. Anker Soundcore Space One Ear Pad Replacement, Ear Pads: step 1, image 1 of 1
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      Ask FixBot
    2. Anker Soundcore Space One Ear Pad Replacement: step 2, image 1 of 2 Anker Soundcore Space One Ear Pad Replacement: step 2, image 2 of 2
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      Ask FixBot
    3. Anker Soundcore Space One Ear Pad Replacement: step 3, image 1 of 1
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      Ask FixBot
Malcolm Hewlett
433 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 23
Past 7 Days: 97
Past 30 Days: 541
All Time: 3,426
