Up to 20% off select tools
Anker Soundcore Space One Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
11
Past 7 Days:
90
Past 30 Days:
376
All Time:
3,333
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Are you experiencing frequent audio static or the power draining faster than usual? If so, use this guide to help fix the batteries in your Anker Soundcore Space One headphones.
An electric battery is a source of electric power consisting of one or more electrochemical cells with external connections for powering electrical devices. A failing battery can cause your headphones to have reduced usage time, inconsistent performance when using it, and a significant decrease in playtime.
Before using this guide, make sure to check out the troubleshooting page about audio distortion. Sometimes, other issues in the device can have similar side effects to a malfunctioning battery.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
    1. Anker Soundcore Space One Battery Replacement, Battery: step 1, image 1 of 1
      • Flip over the device so you can see the Soundcore symbol on the back two ear pieces.
      Ask FixBot
    2. Anker Soundcore Space One Battery Replacement: step 2, image 1 of 2 Anker Soundcore Space One Battery Replacement: step 2, image 2 of 2
      • Take a strong spudger (metal or plastic) and carefully insert it into the lining between the two back ear pieces.
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one
      • Removing the cover can take a couple of minutes. However, don't be aggressive while removing it, as you could damage the interior components under the back earpiece
      Ask FixBot
    3. Anker Soundcore Space One Battery Replacement: step 3, image 1 of 3 Anker Soundcore Space One Battery Replacement: step 3, image 2 of 3 Anker Soundcore Space One Battery Replacement: step 3, image 3 of 3
      • Carefully remove the cover to reveal the battery.
      • Take a spudger and carefully lift the battery from the interior components.
      • Take care not to warp, bend, or puncture the battery.
      • The battery has a layer of adhesive under it. If necessary, use a hairdryer to lightly heat the battery to loosen the battery adhesive.
      Ask FixBot
    4. Anker Soundcore Space One Battery Replacement: step 4, image 1 of 1
      • Lift out the battery.
      Ask FixBot
    5. Anker Soundcore Space One Battery Replacement: step 5, image 1 of 1
      • Desolder the battery connections.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Malcolm Hewlett
433 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 90
Past 30 Days: 376
All Time: 3,333
