Anker Soundcore Select Pro A 3126 Battery Replacement
    1. Anker Soundcore Select Pro A 3126 Battery Replacement, Battery: step 1, image 1 of 2 Anker Soundcore Select Pro A 3126 Battery Replacement, Battery: step 1, image 2 of 2
      • Insert a spudger into the seam between the speaker body and each end cover, then gently pry to remove both side covers.
      Ask FixBot
    2. Anker Soundcore Select Pro A 3126 Battery Replacement: step 2, image 1 of 2 Anker Soundcore Select Pro A 3126 Battery Replacement: step 2, image 2 of 2
      • Insert a spudger into the space between the grille and speaker frame to pry the mesh grille covering the front speakers.
      Ask FixBot
    3. Anker Soundcore Select Pro A 3126 Battery Replacement: step 3, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eight 12.7 mm screws from the front cover.
      Ask FixBot
    4. Anker Soundcore Select Pro A 3126 Battery Replacement: step 4, image 1 of 1
      • Remove four 8.75 mm PH1 screws around the corners of each speaker.
      Ask FixBot
    5. Anker Soundcore Select Pro A 3126 Battery Replacement: step 5, image 1 of 1
      • Flip the speaker so the bottom is facing up.
      • Use a spudger to remove the rubber pads that support the speaker. Insert a spudger under each rubber pad on the bottom of the device and lift them away.
      • If you plan to reuse them, be careful when removing the pads to avoid ripping them.
      Ask FixBot
    6. Anker Soundcore Select Pro A 3126 Battery Replacement: step 6, image 1 of 1
      • Insert a spudger under each rubber pad on the top handle and lift it away to expose the three screws below.
      • Use a Phillips #1 screwdriver to remove the three 6.75 mm screws.
      Ask FixBot
    7. Anker Soundcore Select Pro A 3126 Battery Replacement: step 7, image 1 of 3 Anker Soundcore Select Pro A 3126 Battery Replacement: step 7, image 2 of 3 Anker Soundcore Select Pro A 3126 Battery Replacement: step 7, image 3 of 3
      • Using a spudger, pry open the front half of the speaker.
      • The front and back halves of the speaker are connected by several cables. Open the speaker slowly and avoid pulling on the cables, as they can be damaged easily.
      Ask FixBot
    8. Anker Soundcore Select Pro A 3126 Battery Replacement: step 8, image 1 of 2 Anker Soundcore Select Pro A 3126 Battery Replacement: step 8, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 12.5 mm screws securing the motherboard to the speaker.
      • Remove the motherboard from the device.
      • Remove the two 9.0 mm battery screws to separate the battery from the motherboard.
      • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket to disconnect the battery connector from the motherboard.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • If the connector doesn't release using the spudger, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      Ask FixBot
    9. Anker Soundcore Select Pro A 3126 Battery Replacement: step 9, image 1 of 2 Anker Soundcore Select Pro A 3126 Battery Replacement: step 9, image 2 of 2
      • Carefully peel back the black tape covering the battery in the holder to access it, then replace the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Matthew Garza
390 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 76
All Time: 243
