Anker Soundcore Select 2 A3125 Battery Replacement
    1. Anker Soundcore Select 2 A3125 Battery Replacement, Front Panel: step 1, image 1 of 2 Anker Soundcore Select 2 A3125 Battery Replacement, Front Panel: step 1, image 2 of 2
      • Insert a spudger between the front panel and the speaker housing.
      • Carefully work around the edges of the panel to release the clips securing it.
      • Gently remove the front panel from the main body of the device.
      Ask FixBot
    1. Anker Soundcore Select 2 A3125 Battery Replacement, Speaker Driver: step 2, image 1 of 3 Anker Soundcore Select 2 A3125 Battery Replacement, Speaker Driver: step 2, image 2 of 3 Anker Soundcore Select 2 A3125 Battery Replacement, Speaker Driver: step 2, image 3 of 3
      • Remove the eight 10.0 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a plastic spudger or opening tool between the speaker mount and speaker body to remove the speaker mount covering.
      Ask FixBot
    2. Anker Soundcore Select 2 A3125 Battery Replacement: step 3, image 1 of 3 Anker Soundcore Select 2 A3125 Battery Replacement: step 3, image 2 of 3 Anker Soundcore Select 2 A3125 Battery Replacement: step 3, image 3 of 3
      • Gently lift one speaker up to access the connector on the main board.
      • Use tweezers to grip the plastic connector of the speaker cable and pull it straight out of the socket located on the motherboard.
      • Repeat this process to disconnect the second speaker cable.
      Ask FixBot
    1. Anker Soundcore Select 2 A3125 Battery Replacement, Battery: step 4, image 1 of 2 Anker Soundcore Select 2 A3125 Battery Replacement, Battery: step 4, image 2 of 2
      • Remove the five 5.0 mm screws holding the battery in place using a Phillips #0 screwdriver.
      • To disconnect the speaker panel, use tweezers to grip the plastic connector and pull it straight out of its socket on the motherboard.
      Ask FixBot
    2. Anker Soundcore Select 2 A3125 Battery Replacement: step 5, image 1 of 3 Anker Soundcore Select 2 A3125 Battery Replacement: step 5, image 2 of 3 Anker Soundcore Select 2 A3125 Battery Replacement: step 5, image 3 of 3
      • Use a plastic opening tool to pry the battery out of the speaker casing.
      • Use tweezers to grip the plastic connector and pull it straight out of the socket located on the motherboard
      • Use a small amount of isopropyl alcohol or adhesive remover on a foam swab under the battery to soften the adhesive.
      • The battery is secured with adhesive and may require steady and gentle pressure to lift out.
      • Do not use a metal spudger on the battery as puncturing it is a severe fire hazard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 113
All Time: 468
