Anker Soundcore Q20i Button Assembly Replacement
    1. Anker Soundcore Q20i Button Assembly Replacement, Ear Pads: step 1, image 1 of 1
      • Choose the desired ear cushion to replace.
      • Orient the headphones so that the side of the ear cushion is accessible.
      Ask FixBot
    2. Anker Soundcore Q20i Button Assembly Replacement: step 2, image 1 of 1
      • Wedge an opening tool into the groove where the ear pad meets the driver assembly.
      • Pry the ear pad away from the driver assembly.
      Ask FixBot
    3. Anker Soundcore Q20i Button Assembly Replacement: step 3, image 1 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 3, image 2 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 3, image 3 of 3
      • Repeat Step 2 around the entire perimeter around the ear pad until it is fully detached from the base.
      • Remove the ear pad.
      Ask FixBot
    1. Anker Soundcore Q20i Button Assembly Replacement, LED Diffuser: step 4, image 1 of 2 Anker Soundcore Q20i Button Assembly Replacement, LED Diffuser: step 4, image 2 of 2
      • Remove the four 4.2 mm Phillips #00 screws securing the right driver assembly cover.
      • Lift the driver assembly away from the housing.
      Ask FixBot
    2. Anker Soundcore Q20i Button Assembly Replacement: step 5, image 1 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 5, image 2 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 5, image 3 of 3
      • Identify the LED diffuser.
      Ask FixBot
    3. Anker Soundcore Q20i Button Assembly Replacement: step 6, image 1 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 6, image 2 of 3 Anker Soundcore Q20i Button Assembly Replacement: step 6, image 3 of 3
      • Use tweezers to gently lift the LED diffuser up out.
      Ask FixBot
    1. Anker Soundcore Q20i Button Assembly Replacement, Button Assembly: step 7, image 1 of 2 Anker Soundcore Q20i Button Assembly Replacement, Button Assembly: step 7, image 2 of 2
      • Remove the two Phillips screws securing the motherboard.
      • Gently lift the motherboard out of the chassis, with care not to strain any connected cables.
      • Remove the buttons.
      Ask FixBot
Attached Documents
Derek B.
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 179
