Anker Soundcore Motion Boom Plus Motherboard Replacement
  1. Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: step 1, image 1 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: step 1, image 2 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: step 1, image 3 of 3
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    Ask FixBot
  2. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 2, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 2, image 2 of 2
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    Ask FixBot
  3. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 3, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 3, image 2 of 2
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    Ask FixBot
  4. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 4, image 1 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 4, image 2 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 4, image 3 of 3
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    Ask FixBot
  5. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 5, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 5, image 2 of 2
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    Ask FixBot
  6. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 6, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 6, image 2 of 2
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    Ask FixBot
  7. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 7, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 7, image 2 of 2
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    Ask FixBot
  8. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 8, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 8, image 2 of 2
    • Remove the four 14 mm Philips screws on the top of the device.
    Ask FixBot
  9. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 9, image 1 of 1
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    Ask FixBot
  10. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 10, image 1 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 10, image 2 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 10, image 3 of 3
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    Ask FixBot
  11. Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: step 11, image 1 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: step 11, image 2 of 3 Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: step 11, image 3 of 3
    • Remove the three 12 mm Phillips screws securing the motherboard to the chassis.
    • Remove the two 10 mm Phillips screws surrounding the battery.
    Ask FixBot
  12. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 12, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 12, image 2 of 2
    • Flip the speaker over and push the charging port inward.
    Ask FixBot
  13. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 13, image 1 of 1
    • Slide the motherboard and battery out by pushing through the charging port.
    • The motherboard and battery assembly should detach easily.
    Ask FixBot
  14. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 14, image 1 of 2 Anker Soundcore Motion Boom Plus Motherboard Replacement: step 14, image 2 of 2
    • Remove the five 10 mm Phillips screws securing the motherboard and battery together.
    • Gently lift the motherboard from the battery once all screws are removed.
    • Handle with care to avoid damaging any of the components.
    Ask FixBot
  15. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 15, image 1 of 1
    • Gently pull the motherboard and battery apart.
    Ask FixBot
  16. Anker Soundcore Motion Boom Plus Motherboard Replacement: step 16, image 1 of 1
    • Reconnect the new motherboard to the battery.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
988 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 272
