Anker Soundcore Motion Boom Plus Charging Port Replacement
  1. Anker Soundcore Motion Boom Plus Charging Port Replacement, Case: step 1, image 1 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement, Case: step 1, image 2 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement, Case: step 1, image 3 of 3
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    Ask FixBot
  2. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 2, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 2, image 2 of 2
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    Ask FixBot
  3. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 3, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 3, image 2 of 2
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    Ask FixBot
  4. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 4, image 1 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 4, image 2 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 4, image 3 of 3
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    Ask FixBot
  5. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 5, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 5, image 2 of 2
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    Ask FixBot
  6. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 6, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 6, image 2 of 2
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    Ask FixBot
  7. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 7, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 7, image 2 of 2
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    Ask FixBot
  8. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 8, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 8, image 2 of 2
    • Remove the four 14 mm Philips screws on the top of the device.
    Ask FixBot
  9. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 9, image 1 of 1
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    Ask FixBot
  10. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 10, image 1 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 10, image 2 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 10, image 3 of 3
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    Ask FixBot
  11. Anker Soundcore Motion Boom Plus Charging Port Replacement, Charging Port: step 11, image 1 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement, Charging Port: step 11, image 2 of 3 Anker Soundcore Motion Boom Plus Charging Port Replacement, Charging Port: step 11, image 3 of 3
    • Remove the three 12 mm Phillips screws securing the motherboard to the case.
    • Remove the two 10 mm Phillips screws surrounding the battery.
    Ask FixBot
  12. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 12, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 12, image 2 of 2
    • Flip the speaker over and push the charging port inward.
    Ask FixBot
  13. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 13, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 13, image 2 of 2
    • Slide the motherboard and battery out by pushing through the charging port.
    • The motherboard and battery assembly should detach easily.
    Ask FixBot
  14. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 14, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 14, image 2 of 2
    • Remove the five 10 mm Phillips screws securing the motherboard and battery together.
    • Gently lift the motherboard from the battery once all screws are removed.
    • Handle with care to avoid damaging any of the components.
    Ask FixBot
  15. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 15, image 1 of 1
    • Gently pull the motherboard and battery apart.
    Ask FixBot
  16. Anker Soundcore Motion Boom Plus Charging Port Replacement: step 16, image 1 of 2 Anker Soundcore Motion Boom Plus Charging Port Replacement: step 16, image 2 of 2
    • Remove the battery from the silicone/plastic holder and replace it.
    • The replacement should have a new charging port attached to it.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
988 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 33
All Time: 257
