Anker Soundcore Motion Boom Plus Battery Replacement
  1. Anker Soundcore Motion Boom Plus Battery Replacement, Case: step 1, image 1 of 3 Anker Soundcore Motion Boom Plus Battery Replacement, Case: step 1, image 2 of 3 Anker Soundcore Motion Boom Plus Battery Replacement, Case: step 1, image 3 of 3
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    Ask FixBot
  2. Anker Soundcore Motion Boom Plus Battery Replacement: step 2, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 2, image 2 of 2
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    Ask FixBot
  3. Anker Soundcore Motion Boom Plus Battery Replacement: step 3, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 3, image 2 of 2
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    Ask FixBot
  4. Anker Soundcore Motion Boom Plus Battery Replacement: step 4, image 1 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 4, image 2 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 4, image 3 of 3
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    Ask FixBot
  5. Anker Soundcore Motion Boom Plus Battery Replacement: step 5, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 5, image 2 of 2
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    Ask FixBot
  6. Anker Soundcore Motion Boom Plus Battery Replacement: step 6, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 6, image 2 of 2
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    Ask FixBot
  7. Anker Soundcore Motion Boom Plus Battery Replacement: step 7, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 7, image 2 of 2
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    Ask FixBot
  8. Anker Soundcore Motion Boom Plus Battery Replacement: step 8, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 8, image 2 of 2
    • Remove the four 14 mm Philips screws on the top of the device.
    Ask FixBot
  9. Anker Soundcore Motion Boom Plus Battery Replacement: step 9, image 1 of 1
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    Ask FixBot
  10. Anker Soundcore Motion Boom Plus Battery Replacement: step 10, image 1 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 10, image 2 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 10, image 3 of 3
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    Ask FixBot
  11. Anker Soundcore Motion Boom Plus Battery Replacement, Battery: step 11, image 1 of 3 Anker Soundcore Motion Boom Plus Battery Replacement, Battery: step 11, image 2 of 3 Anker Soundcore Motion Boom Plus Battery Replacement, Battery: step 11, image 3 of 3
    • Remove the four 11 mm Phillips screws securing the subwoofer.
    • Gently pull the subwoofer out of the device.
    Ask FixBot
  12. Anker Soundcore Motion Boom Plus Battery Replacement: step 12, image 1 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 12, image 2 of 3 Anker Soundcore Motion Boom Plus Battery Replacement: step 12, image 3 of 3
    • Remove the three 12 mm Phillips screws surrounding the motherboard using a screwdriver.
    • Remove the two 10 mm Phillips screws surrounding the battery.
    Ask FixBot
  13. Anker Soundcore Motion Boom Plus Battery Replacement: step 13, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 13, image 2 of 2
    • Flip the speaker over and push the charging port inwards.
    Ask FixBot
  14. Anker Soundcore Motion Boom Plus Battery Replacement: step 14, image 1 of 1
    • Slide the motherboard and battery out by pushing through the charging port.
    • The motherboard and battery assembly should detach easily.
    Ask FixBot
  15. Anker Soundcore Motion Boom Plus Battery Replacement: step 15, image 1 of 2 Anker Soundcore Motion Boom Plus Battery Replacement: step 15, image 2 of 2
    • Remove the five 10 mm Phillips screws securing the motherboard and battery together.
    • Gently lift the motherboard from the battery once all screws are removed.
    • Handle with care to avoid damaging any of the components.
    Ask FixBot
  16. Anker Soundcore Motion Boom Plus Battery Replacement: step 16, image 1 of 1
    • Gently pull the motherboard and battery apart.
    Ask FixBot
  17. Anker Soundcore Motion Boom Plus Battery Replacement: step 17, image 1 of 1
    • Position and reconnect the new battery where the old battery was located.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
988 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 108
All Time: 841
