Introduction
Is the Charging Port on your Anker Soundcore Motion 3000 speaker loose, broken, or not charging the device properly? Then all you need is your Philip’s head screwdriver #0, the blue plastic opening tool, a heating gun (if necessary) and this replacement guide to help you fix this issue.
Insert an opening tool into a seam between the grille and chassis.
Gently pry the grille up to begin disengaging the retaining clip.
Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the speaker housing.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
