Anker Soundcore Life Q30 Battery Replacement
Views: 8.2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
94
Past 30 Days:
449
All Time:
8,194
Comments: 13
7 comments on steps, 6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in the Anker Soundcore Life Q30 headphones. The battery is what allows power and charge through the headphones, so a faulty battery can cause the headphones to become weak or not turn on at all. Replacing this will require you to resolder the replacement battery to the circuit board. Before you begin, make sure to turn off the headphones and unplug them from their charger.
Tools
    1. Anker Soundcore Life Q30 Battery Replacement, Headphone Driver: step 1, image 1 of 2 Anker Soundcore Life Q30 Battery Replacement, Headphone Driver: step 1, image 2 of 2
      • Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
      • Adjust the folding hinge to where the speakers are facing up.
      • Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
      Ask FixBot
    2. Anker Soundcore Life Q30 Battery Replacement: step 2, image 1 of 3 Anker Soundcore Life Q30 Battery Replacement: step 2, image 2 of 3 Anker Soundcore Life Q30 Battery Replacement: step 2, image 3 of 3
      • Using one hand, hold the right side of the headphones still.
      • Using your other hand, slide the plastic opening tool in the edge along the cushion.
      • Gently pry the cushion off using the plastic opening tool.
      • Set the right ear cushion aside and repeat this step for the left side of the headphones.
      Ask FixBot
    3. Anker Soundcore Life Q30 Battery Replacement: step 3, image 1 of 3 Anker Soundcore Life Q30 Battery Replacement: step 3, image 2 of 3 Anker Soundcore Life Q30 Battery Replacement: step 3, image 3 of 3
      • Remove the four 5.7 mm screws from the headphone driver using a Phillips #00 screwdriver.
      • Pull the headphone driver apart from the headphones.
      • If you’re having difficulty doing so without any tools, use tweezers to get a better grip on it.
      Ask FixBot
    4. Anker Soundcore Life Q30 Battery Replacement: step 4, image 1 of 2 Anker Soundcore Life Q30 Battery Replacement: step 4, image 2 of 2
      • Lift the drivers out of the headphones.
      • Remove the wires from the circuit board that connect the drivers.
      • Take note of where the wires are connected, as you will have to solder them back to the circuit board.
      Ask FixBot
    1. Anker Soundcore Life Q30 Battery Replacement, Battery: step 5, image 1 of 3 Anker Soundcore Life Q30 Battery Replacement, Battery: step 5, image 2 of 3 Anker Soundcore Life Q30 Battery Replacement, Battery: step 5, image 3 of 3
      • Pull the microphone (circular blue part) from its socket by the connected red wire that is covered in black rubber.
      • Take note of where the microphone is, as you will have to reconnect it.
      • The wire itself is connected to the battery and will disconnect the battery from the exterior piece of the earcup.
      • Unscrew the four 5.7 mm screws with a Phillips #00 screwdriver connecting the earcup to the headphone’s frame.
      • Remove the earcup.
      Ask FixBot
    2. Anker Soundcore Life Q30 Battery Replacement: step 6, image 1 of 2 Anker Soundcore Life Q30 Battery Replacement: step 6, image 2 of 2
      • Unscrew the 5.7mm screw with a Phillips #00 screwdriver within the green circuit board connected to the battery.
      • Carefully pry the green circuit board and battery off of the earcup.
      • The battery may be glued into place, which will require some force to remove.
      Ask FixBot
    3. Anker Soundcore Life Q30 Battery Replacement: step 7, image 1 of 2 Anker Soundcore Life Q30 Battery Replacement: step 7, image 2 of 2
      • If you are following this guide to reach the buttons, ignore this step.
      • Remove the wires connecting the battery from the circuit board.
      • Note the placement of the wires you remove, as you will have to solder them back into place.
      Ask FixBot
From here, you’ll have to solder your replacement battery into place. After doing so, follow these steps in reverse order to reassemble the device.
6 Guide Comments
donde se compran las baterías?
Branly Saul - Reply Share
The batteries dimensions are 35x30mm i had great difficulty finding this size and just went for a 750Mah one. Which was too long. There really is no wiggle room on any axis!
Also, most everything is glued in, the microphone on the side is pretty much impossible to remove without causing permanent damage. I dissembled to step 4. Then VERY carefully pried the battery out (Which is also glued in) mine was already pretty swollen. And i replaced the battery with that of an old Vape. It works but its hacky and ill advised probably. So make sure you get the right size before you disassemble them.
Alice Inesophet - Reply Share
Got this replacement battery from AliExpress (slightly different from the original):
https://www.aliexpress.com/item/10050049...
I didn’t need to do any soldering. I left the drivers and microphone connected, cut the original battery wires, and connected the new battery wires directly to those.
Everything seems to be working fine so far.
sohaib aumer - Reply Share
Did you tape the wires? How did you connect them so that they'd fit?
notdogen - Reply Share
@notdogen - cut the wires as close to the old battery as possible (remember to cut one wire at a time to prevent an unintentional short).
Then cut the wires of the new battery as close to the battery connector as possible (if included with the battery).
Connect the new battery to the old wires: red to red & black to black, then seal with liberal ampunts of electrical tape. if possible, tape both to the panel you unscrewed below the ear pads.
Tape the battery down, then reassemble the headphones
Terdoo George - Reply Share
Past 24 Hours: 9
Past 7 Days: 94
Past 30 Days: 449
All Time: 8,194
