Introduction
If you want to replace the buttons on the Anker Soundcore Life Q20 headphones, follow this guide to remove and replace them. The buttons sit within the base of the headphones and allow you to control the volume, power, and noise cancellation. They are located on both sides of the headphones.
The buttons are crucial to the use of the headphones and allow you to control the many functions available. They may need to be replaced if they are not working properly or are broken.
Choose the desired ear cushion to replace.
Orient the headphones so that the side of the ear cushion is accessible.
Use a Phillips #00 screwdriver to remove the four 10 mm screws from the cover.
Remove the cover to expose the battery.
Use your index finger to lift the battery and remove it from the base.
Desolder the battery from the board, following the instructions from the iFixit soldering guide: How To Solder and Desolder Connections
Using the Phillips #00 screwdriver, remove the two 7 mm screws from the green board.
