Anker Soundcore Life Q20 Battery Replacement
  1. Anker Soundcore Life Q20 Battery Replacement, Ear Cushion: step 1, image 1 of 1
    • Choose the desired ear cushion to replace.
    • Orient the headphones so that the side of the ear cushion is accessible.
    Ask FixBot
  2. Anker Soundcore Life Q20 Battery Replacement: step 2, image 1 of 2 Anker Soundcore Life Q20 Battery Replacement: step 2, image 2 of 2
    • Wedge the iFixit opening tool into the groove where the ear cushion meets the base of the headphones.
    • Pry the ear cushion apart from the base.
    Ask FixBot
  3. Anker Soundcore Life Q20 Battery Replacement: step 3, image 1 of 2 Anker Soundcore Life Q20 Battery Replacement: step 3, image 2 of 2
    • Repeat step 2 in a rotation around the ear cushion until it is fully detached from the base.
    Ask FixBot
  4. Anker Soundcore Life Q20 Battery Replacement, Battery: step 4, image 1 of 3 Anker Soundcore Life Q20 Battery Replacement, Battery: step 4, image 2 of 3 Anker Soundcore Life Q20 Battery Replacement, Battery: step 4, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws from the cover.
    • Remove the cover to expose the battery.
    Ask FixBot
  5. Anker Soundcore Life Q20 Battery Replacement: step 5, image 1 of 1
    • Use your index finger to lift the battery and remove it from the base.
    • Desolder the battery from the board, following the instructions from the iFixit soldering guide: How To Solder and Desolder Connections
    Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 53
Past 30 Days: 241
All Time: 3,134
